It is currently Mon Nov 16, 2026 1:02 am
PostPosted: Sun Jun 24, 2012 5:51 pm
Okay, the Pertronix coil with 3.0 ohm resistance is in. I have a 4-prong ballast resistor, so to bypass it do I run a jumper from one side to the other? Thanks!
'78 Volare 225
'67 Charger 318
PostPosted: Sun Jun 24, 2012 5:53 pm
.Okay, one jumper on top, and one on bottom, from side to side.
'78 Volare 225
'67 Charger 318
PostPosted: Mon Jun 25, 2012 1:02 pm
Take a look at the pictures on the red link below. I have two good pictures. ones with the resistor and with out....
I did have a dual style resistor.....
PostPosted: Mon Jun 25, 2012 1:36 pm
Jumpered
There is the "jumpered" pic
MRO....
Cheap, Fast, Reliable.... Pick 2...
PostPosted: Mon Jun 25, 2012 8:35 pm
Thanks guys. Well, I have a spare ballast resistor in my garage, so with a multimeter I checked where there was continuity, and where there was not. I then installed the two jumpers that made. The Volare runs and starts fine, so I guess that all is well.
Thanks for the responses! :D :D :D
And thank you Ted, for "field testing" this coil. 8)
'78 Volare 225
'67 Charger 318
PostPosted: Tue Jun 26, 2012 5:59 am
Ted, I saw your message, thanks. Rather than twist the blue wires together, I just used two jumper wires, and I left the ballast resistor in place. That way, if the Pertronix coil ever does go out, I can reconnect the ballast resistor and use a stock type coil. I'm a bit cautious/paranoid in my middle age!
Thanks for your help.
Wes
'78 Volare 225
'67 Charger 318
