It is currently Thu May 21, 2026 7:04 am
PostPosted: Tue Jul 03, 2012 9:32 pm
What's better?
Making vertical loops or horizontal loops in the brake lines from the master cylinder?
63 Signet / 10 inch front drums / weber 2bbl / HEI / 2.76 rear end
PostPosted: Tue Jul 03, 2012 9:43 pm
I'd think horizontal so there isn't multiple high spots for air to get stuck.....
Start high (next to master), then circle down horizontally.
Plus, I don't think I've ever seen any vertical ones either.
PostPosted: Tue Jul 03, 2012 9:54 pm
You want vertical loops in the lines from the master cylinder down to the combination valve or splitter, just like the factory put. They're there for a reason: to allow the lines to flex without work-hardening and becoming brittle.
PostPosted: Tue Jul 03, 2012 10:03 pm
That makes sense.
But I just saw some vertical ones on a 1968 Valiant.
But maybe they weren't stock.
Or maybe it was stock?
(edited after I read SSD's post)
PostPosted: Tue Jul 03, 2012 11:34 pm
Yup, the vertical loop-de-loops you saw were stock.
PostPosted: Tue Jul 03, 2012 11:52 pm
Just so I'm sure we all using the same definitions:
I consider this to be a horizontal loop:
Loop is horizontal, flow direction is vertical.
Vertical loops are turned 90 degrees so
Loop is vertical, flow direction is horizontal.
PostPosted: Wed Jul 04, 2012 2:40 am
I would agree with that statement, BUT after seeing SSD's post maybe we need to see if he speaks again... Maybe your and my definitions are different than his... I dont think I have seen any 'vertical' loops in brake lines either, if our thoughts are the same.
MRO....
Cheap, Fast, Reliable.... Pick 2...
PostPosted: Wed Jul 04, 2012 6:34 am
This was on a 1968 Valiant.
This is what I would call vertical loops.
They were clipped together with a metal S clip. It looked like the factory did it.
PostPosted: Wed Jul 04, 2012 1:59 pm
...multiple high spots for air to get stuck...
No. There are plenty high spots all the way along a brake line. Unless you have so much moisture in very old brake fluid as to cause a steam bubble in a high spot because of local heat, a normal brake bleed job will clear away all the air bubbles. If air in a brake line remains a problem, leave the bleeding to a brake pro. Always bench bleed the master cylinder.
Olaf
Aspenized
PostPosted: Wed Jul 04, 2012 3:29 pm
Everyone's on the same page: we all mean the same thing when we say "horizontal" and "vertical", and neither type of loop should cause problems with air bubbles. Seeing emsvitil's pic I am guessing(!) the horizontal loops would provide enough line flex if there were enough coils to the loop-de-loop. Guess I should look under the hood of my '91 Spirit and see what they put in that.
»time passes«
Vertical loops in the '91 Spirit.
PostPosted: Sun Jan 20, 2013 2:04 pm
The coils should lie in the vertical plane. If they are in the horizontal plane, they will continually flex and vibrate as the car hits bumps in the road...possibly leading to fatigue fractures.
Ken
