It is currently Tue May 19, 2026 10:29 am
PostPosted: Thu Jul 05, 2012 5:04 am
I am running a 225 with power steering. Wanting to add air con.
Can anyone tell me what pulleys I will need to run from the crankshaft and water pump to accommodate the air con belt, please?
Thanks
Gary
Gary from Downunder
2 weeks ago I couldn't even spell mukanic - now I are one!
PostPosted: Thu Jul 05, 2012 11:23 am
Save yourself a great deal of hassle: get the compressor mount kit from Charrlie_S on here. It's much better designed than any of the off-shelf aftermarket compressor mount kits available up here (though perhaps you might have different options down there).
You will need to add another belt sheave to the crank pulley, or else swap on one of these.
 Post subject: Thanks Dan (again)
PostPosted: Fri Jul 06, 2012 5:59 am
OH yeah, that's the sort of answer that I was looking for - thanks Dan.
Wasn't really sure of how they would set it up - and thanks for the tip to PM Charrlie_S.
As always, your help and advice is appreciated
Regards
Gary
Gary from Downunder
