It is currently Sat Jul 18, 2026 7:03 pm
PostPosted: Tue Jul 10, 2012 6:19 pm
Hello,
I just got a 750 Holley To try out on ruster.
Having never messed with a holley carb other than stock 1bbl stuff..
I ham having a fuel drip-leak issue with the 3/8 Inverted flare fittings that go into the fuel bowl.
is there supposed to be a gasket in on both sides of Holley part # 26-26?
I have the large 7/8" gasket on both the front and rear bowls... But is there a gasket that goes in the flare fitting location as well?
If we look at holley part #26-26 from the summit racing site, it has both the large and a small gasket pictured... Is my lack of having these small gaskets causing my fuel drip??
I have never needed to use a gasket on any other flare fitting I have used before so this is kind of giving me a challenge to get the leaks sealed up.
Thanks,
PostPosted: Tue Jul 10, 2012 7:16 pm
Greg, I have never used anything but the larger O ring type seal on the bowl side of the fitting.
I am interested to see how the bigger carb works too. :D
PostPosted: Tue Jul 10, 2012 7:41 pm
We shall see.
I know I will need to disable or modify the secondary accelerator pump shot.
The Primary accelerator pump shot might be a bit fat now... but It's hard to do any of that tuning if the dang thing leaks fuel on the headers.
PostPosted: Tue Jul 10, 2012 8:04 pm
Nope just the bowl gasket.. Sounds to me like a flaw of some kind in the line... I am not familiar with your build or carb, but a 750 is a pretty large carb...
Are you using just "stubs" and rubber hoses or the dual feed line? After time the feed lines do seem to "develop" leaks.
MRO....
PostPosted: Wed Jul 11, 2012 5:04 am
Yes 750 is a large carb, but this is an all-out WOT drag race engine in a light car.
I went from a 500 CFM carter AFB to a 750 CFM carter AFB and the car went 0.2 seconds faster.. Trying the holley HP 750 to see what it will do.
I am using the Fuel line kit, not the stubs and rubber hoses.. ordered 2 new part # 26-26's Maybve I over tightned the first time and caused a leak... also Tha carb was used so maybe there is other junk going on.
Here is some Info on this project.
 Post subject: Holley
PostPosted: Wed Jul 11, 2012 12:52 pm
Let's see? You have fuel leaks. And you need to start tuning it, and probably keep tuning it forever, and ever! Yep, you definitely bought a Holley! :lol: :lol:
Just teasing Greg! Hope you pick up a bit more. Soon you will be knocking on eleven's door!!! The company gets pretty exclusive there, especially N/A
Good Luck,
Rick
PS. Have a great wedding day Saturday!!
PostPosted: Thu Jul 12, 2012 4:19 pm
I used pipe dope on my screw ins into the fuel bowl worked fine for me
Kev
PostPosted: Fri Jul 13, 2012 8:09 pm
Got everything worked out on this..
THe Flares were not sealing correctly against the inside of the fitting.. Seems like a common problem..
I made my own flares on some 3/8" tube stock and left a little "cushion" in the flare so it would seal against the holley 26-26 Fitting.. The little cork gasket is for a holley ceramic fuel filter in the fuel bowls.. and You are never supposed to use pipe dope or teflon on flare threads - THe threads do not seal like in a pipe fitting.. THe flare does.
As I have never ever had any trouble with any of the 3/16" flares for brakes etc.. I was second guessing the 3/8" flares.. But I got it all figured out now.
PostPosted: Fri Jul 13, 2012 8:43 pm
Well, I use teflon tape on flare threads............
Not for sealing anything, it just easier to take things apart later if the pieces haven't rust welded together......
PostPosted: Wed Jul 18, 2012 8:04 am
Ah ok... wasnt doubting you or your cfm needs was mainly thinking out loud... :lol: it gets me in trouble ALOT. :wink: WOW!! a 45 page build thread... Looks like i have some reading to do... :lol: :lol:
Dang got to the first vid and 'bucket said media soesnt exist.. :? Page 8 or so... :lol:
MRO....
