It is currently Fri May 22, 2026 7:49 pm
 Post subject: 833 question
PostPosted: Fri Jul 13, 2012 12:52 pm
OK i have a 4spd of some sort, i was told a OD, its has the long tail shaft, not sure if that matter's or not, but how would i find out?? if i posted some pics on here could you guys tell me?? i just want to make sure its a OD unit
PostPosted: Fri Jul 13, 2012 1:12 pm
Have you read this? http://www.slantsix.org/articles/4-spee ... speed1.htm
PostPosted: Fri Jul 13, 2012 4:29 pm
yes i have read that
PostPosted: Fri Jul 13, 2012 6:24 pm
Short tailshaft has only one mounting boss for the shifter assembly near the end (A/F body), long tail typically has two mounting points, or only one close to the front (B/C/E/truck/van).
O/D units have a bigger flange around the input bearing (where the shaft goes into the front of the trans.) @5.125". Also, the shift lever closest to the front of the trans. points down on an O/D trans., up on a non O/D.
That info and much more is covered in the article Josh linked to.
PostPosted: Fri Jul 13, 2012 7:46 pm
Yep just measure the front bearing retainer, IF its a hair over 5" then its OD. (if the shifter arms are not on it) If its less than 5" its a NON-O/D trans...
MRO....
Cheap, Fast, Reliable.... Pick 2...
 Post subject: But...
PostPosted: Fri Jul 13, 2012 9:39 pm
That is mostly true...but if someone wanted to install a normal A-833 into the OD Bellhousing, and swapped a Bearing Retainer from a 1976+ 3spd (like the A-230....Mopar didn't want to redrill the last of the 3 speeds so they have small bolt retainer pattern like the normal 833 and early 903/745...)...then the bearing retainer OD would be 5.125" and the tranny would be a normal 4 speed..
:wink:
