It is currently Tue Jun 02, 2026 11:10 pm
PostPosted: Tue Jul 17, 2012 2:45 pm
A buddy of mine told me about doing this to static lower my '73 Dart in the rear...
What's the worst that could happen? Just wanna find out before further thoughts...
"Chrome don't get ya home."
<img src=http://i54.tinypic.com/iznqiu.jpg>
1973 Dodge Dart Custom aka Duh Fart
PostPosted: Tue Jul 17, 2012 4:22 pm
I have seen a few friends who have done the flip and they never had any issues, it really doesn't make a big diffrence an 1" I believe. How ever one friend had some bad vibes in his drive shaft which he changed out and problem was solved.
So when ever you change the suspension from stock make sure you check your geometry and suspension angles or you may have premature failure of parts. [/img]
PostPosted: Tue Jul 17, 2012 4:31 pm
You have to flip them and swap them side for side.
You will need to do a little drilling
I did it sometime in the last century ,,,,,no ill effects.
PostPosted: Tue Jul 17, 2012 5:02 pm
He mentioned nothing about doing the side to side swap but makes sense! Thanks for the help ya'll.
PostPosted: Tue Jul 17, 2012 5:04 pm
How many inches do you think it was lowered by doing this?
PostPosted: Tue Jul 17, 2012 5:09 pm
The left and right brackets are the same. Problem is the top and bottom bolt hole spacing is different so you either move the studs in the bracket or oval the holes in the chassis. I used a die grinder to oval the holes in the chassis on my '66 Dart. On my '66 Barracuda I added material to the spring hanger and drilled higher spring eye holes so that I had two ride height positions.
PostPosted: Sun Sep 02, 2012 8:23 am
You can buy new hangers with the second eye bolt hole from Firm Feel. Then you don't need to oval out the holes in the sheet metal.
