It is currently Sun Nov 29, 2026 4:55 pm
PostPosted: Sat Jul 14, 2012 2:28 pm
Loose spark plugs aren't good. What plugs are you running? Did you remove the metal ring washers from them before installation?
PostPosted: Sat Jul 14, 2012 2:47 pm
I'm using the NGK plugs you recommend, can't recall the product # but they're the right ones. And yes I removed the metal rings.
"Chrome don't get ya home."
<img src=http://i54.tinypic.com/iznqiu.jpg>
1973 Dodge Dart Custom aka Duh Fart
PostPosted: Sat Jul 14, 2012 3:09 pm
Tighten them up to the specified torque, but I don't think that's the main cause of your problem.
I still think the problem is probably in your carburetor. See my earlier comments (float, etc.)
PostPosted: Sun Jul 15, 2012 11:15 am
Thanks Dan!
PostPosted: Sat Jul 21, 2012 8:40 am
Dan, I checked my float and all is fine with it. I'm having the problem again with constant stumbling. The car has always had a little miss to it. When warm it wants to cut off whenever I am in gear. I'll give it a good rev and it'll backfire through the carb, then smooth out and stop missing and run great. Is this a stuck valve?
PostPosted: Sat Jul 21, 2012 10:17 am
I'm not yet convinced. How'd you check it?
Probably not.
You may be due for a new carburetor; send me a PM if you're in the market.
PostPosted: Sat Jul 21, 2012 10:48 am
PM sent!
