It is currently Tue Dec 23, 2025 7:52 pm
PostPosted: Sat Jul 21, 2012 1:27 pm
Was thinking that the 74 Dart is going to get scrapped. I was thinking of keeping the K member for the spool mounts and swap it to the Duster some day. I have a sway bar and mounts. Is mounting for the sway bar going to be different?
'72 Duster 198 stock cam, 3:23's Hookers on jack stands for 8 years in the driveway
'79 Maxivan 360 Offy Qjet Comp RV cam/rusting in the driveway.
93 D350 160HP Cummins Auto :-( Dually Clubcab needs a injector pump
2005 Golden Couch Buick
 Post subject: Yep...
PostPosted: Sat Jul 21, 2012 7:06 pm
The 73-76 mounting method is a little different than the 67-72 method...
But I'm sure that you could get the late sway bar and mounts to fit the other K-member with some drilling and welding...
