It is currently Thu May 28, 2026 9:57 am
 Post subject: Under Coating Removal
PostPosted: Wed Jul 18, 2012 6:29 pm
Tried everything else every which way..this is the best tool for the job.
Here is a top of the line multi-tool, Bosch also make one thats cheaper.
The blades are pricey, a used one with all the teeth broken off is the way to go.
This bugger should shave at least 10-15 lbs of your ride.
<img src="http://farm4.static.flickr.com/3173/2992308402_5481afb26e_t.jpg">
PostPosted: Sun Jul 22, 2012 4:24 am
Great tip - thanks.
Gary from Downunder
2 weeks ago I couldn't even spell mukanic - now I are one!
PostPosted: Sun Jul 22, 2012 7:26 am
A heat gun makes things go MUCH faster. Just don't let the stuff fall on you. And keep the tip of the gun away from heat sensitive stuff, which would include your cloths and skin.
Sam
PostPosted: Sun Jul 22, 2012 8:19 am
yes looks like it be a time saver...have used heatgun and stiff puttyknive to remove ...heat helps alot ...be careful....once hot it becomes sticky like to your skin =bad burns
