It is currently Sun Nov 29, 2026 8:18 pm
PostPosted: Tue Jul 24, 2012 7:06 pm
Car Model: 1977 B100 Van
I am looking to refresh all of the vacuum lines on my van. I disconnected and measured all I could, but still have a few potentially dumb questions:
1/ PCV line is cracked and probably leaking.
Should I replace it with the same 5/16" fuel injection hose SlantSixDan recommends for the fuel line mod or another type will do?
2/ Air cleaner, choke pull-off and distributor hoses seems to be 3/16" ID.
The outside diameters are different though, should I care?
3/ Other hoses still have their colored stripes (white, blue and yellow) and given their condition, they probably are the original ones.
I think they all are 3/32", but I wasn't able to disconnect them separately since they merge into one piece that connects into the Vacuum amplifier.
Same problem at the CCEGR valve.
Am I missing something obvious here? How can I replace them?
4/ Carburetor to ECS, any type of hose I should use in particular?
"Hey, I like that paint job you got. What they call that--sorta a cross between Piss Yellow and Puke Green, ain't it?" -- Bob Falfa
PostPosted: Tue Jul 24, 2012 10:20 pm
I will go out on a limb and say regular vacuum hose will work for all the connections, no need for the special fuel injection line hose since none of these hoses will be carrying fuel. I will also posit that it is the inner diameter of the hose that matters, since that is what is necessary to make a tight connection to the fitting.
As far as the connection to the vacuum amplifier goes, you may be better off trying to find a good condition used assembly. I am not aware of a way to disassemble the connecter hat goes to the hockey puck.
PostPosted: Tue Jul 24, 2012 10:51 pm
The PCV hose needs to be oilproof; regular plain rubber hose will swell and degrade quickly. Fuel line hose is fine, too, but no need to get the expensive fuel injection stuff. The correct diameter is 11/32", but that's often hard to find so 3/8" with appropriate hose clamps is an acceptable substitute.
The breather hose (from crankcase breather to air cleaner) needs to be actual breather hose -- oil resistant. Not heater hose.
Everything else: plain vacuum hose.
PostPosted: Tue Jul 24, 2012 11:19 pm
No wonder some of the vacuum lines I replace start to get sticky after a few months. Thanks for setting me straight.
PostPosted: Wed Jul 25, 2012 4:50 am
Thanks so much, guys :)
So, either I keep the EGR setup the way it is and eventually find one in better shape at the junkyard, or I'll have to bypass the whole thing? :shock:
