It is currently Thu Oct 08, 2026 12:41 am
PostPosted: Tue Aug 07, 2012 6:06 am
what kind of options do i have? would like to build a higher compression turbo motor and use the stock push rods and adj rockers and a small t3/4 turbo with about 1-12 psi for a nice tq'y street motor
1980 Aspen 4 speed
PostPosted: Tue Aug 07, 2012 9:28 am
Soooo... what is the question?
Do you want a cam designed for a future turbo build or ??
PostPosted: Tue Aug 07, 2012 10:23 am
yes sorry what kind of grinds are out there to already without having a custom grind done? would like to deck the block to up the compression a little more to 8.5 mabe and not need custom push rods.
How much adjustment is in the rockers ?
1980 Aspen 4 speed
PostPosted: Tue Aug 07, 2012 10:35 am
Use the search button. These issues have been discussed numerous times before in great depth.
PostPosted: Tue Aug 07, 2012 10:42 am
A factory cam would be fine for what you have planned.
The next step up would be an Erson RV10 - 295 RDP grind.
PostPosted: Tue Aug 07, 2012 10:59 am
yes just not alot on the solid lifter side just wondering about the pushrods
1980 Aspen 4 speed
 Post subject: Why???
PostPosted: Tue Aug 07, 2012 7:43 pm
If you don't cut much off the head or deck and your adjustment screws are in the "middle" of the threading for adjustment, then you could probably reuse them...It doesn't take much to bend them though, so if you decide to get the headwork done and change to a set of double springs like 340 springs, you may want to opt to go with a custom pushrod that 3/8" and moly instead of the 5/16" stockers... If you cut about .1 or more out of a "late" engine (say 1973+), you will need to check the geometry of the pushrod cup to the rocker arm.
Most of the choices in this field are "custom" and not just something to pick out of a catalog like "brand x"...luckily there are companies that are willing to work with you for less cost than a catalog comp cam let's say.
Users browsing this forum: Bing [Bot] and 21 guests
