It is currently Fri Oct 09, 2026 8:30 am
Post new topic  Reply to topic  [ 27 posts ]  Go to page 1 2 Next
 Post subject: install?????s
PostPosted: Tue Aug 14, 2012 10:26 am
help am alone ..no help[ ....have w-150,four speed....tran/transfercase still in truck .....engine has bell/clutch on it.... have jack under tran ,and engine hung on chainhoist/tripod...my problem is I can not get them to line up/drop together by myself,have been wiggleing /readjusting chain/jack for days now ....any hints????tips???? that I am overlooking????? HELP PLEASE
PostPosted: Tue Aug 14, 2012 10:34 am
Can you describe where the assembly is hanging up and not going into place? Are you having a clearance issue between the bottom of the truck and the ground?
PostPosted: Tue Aug 14, 2012 10:42 am
it is about two inches from sliding together, both motormounts are off....it bloody just dont want to slide together
PostPosted: Tue Aug 14, 2012 11:15 am
Are the dowel pins lining up? The trans could have twisted when the engine was removed and thrown off the alignment.
Could your splines on the trans be off just a touch?
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Tue Aug 14, 2012 11:38 am
Use 2 long bolts or lengths of 7/16-14 threaded stock to go from the engine thru holes & into the bellhousing threaded holes, to help get the rotational alignment correct. (I use old SL6 head bolts)
Put the trans in gear and slowly rotate the output flange, you should feel the clutch to input shaft splines "clicking" against each other, as you rotate. (If you are in far enough)
At the point, turn & "Feel" your way into the clutch disc splines, then into the pilot bushing.
Did you use a good quality pilot / alignment tool to get the disc centered?
PostPosted: Tue Aug 14, 2012 11:49 am
thanks Doc
"Did you use a good quality pilot / alignment tool to get the disc centered? "
yes
PostPosted: Tue Aug 14, 2012 12:12 pm
head bolts too long and too small...found bolt from rear bearingcaps that are a bit small ,but lenght about right.....still not sliding together .....eeeeerrrrr
PostPosted: Tue Aug 14, 2012 12:31 pm
can you re insert the clutch pilot alignment tool into clutch plate through the bearing retainer hole in the flywheel housing ?
you will need to remove the throw out bearing and arm...
if it is set properly,,like Doc mentioned, the splines are not meshing, give the tranny input a little twist..
PostPosted: Sat Aug 18, 2012 6:17 pm
it is a w-150 4 wheel drive , has the big clutch,oversized bell,which need to be bolted to engine before flywheel.....so no turning output shaft....now have throwout arm removed, pressure plate unbolted......need to pry apart trans/engine to free /alaine clutch plate......just been hurting tooo much to do anything......
 Post subject: ???
PostPosted: Sat Aug 18, 2012 6:59 pm
You got the right splines? I know that the early NP 435's had a course spline input shaft (I wasn't 23...)
-D.idiot
PostPosted: Sun Aug 19, 2012 4:07 am
same clutch/trans...were together before...just being PITA
PostPosted: Sun Aug 19, 2012 6:11 am
motor mounts on backwards?
1980 Aspen 4 speed
PostPosted: Sun Aug 19, 2012 1:31 pm
no it the clutch giveing all the problem and is the same one that was there before...that and a bum shoulder/wrist ...yea both on the right arm..and noone to help...but I will get it
keep on roddin'
PostPosted: Wed Aug 22, 2012 12:56 pm
eeeeerrrrrrrrrrr....have release arm out, throwout bearing slide back on shaft,pressure plate slide back,two inch block of wood holding trans back away bell.....clutch plate WILL NOT SLIDE ON SHAFT ...engine on hoist,jack under trans IOD inatate object defiance
PostPosted: Wed Aug 22, 2012 1:44 pm
The last 2 I did, had to be drawn in with long bolts, like Doc said. tighten bolts a little, shake engine./tranny, repeat,repeat.......etc. It will go in. :lol: :lol:
Good luck,
Rick
Users browsing this forum: 66darter, Charrlie_S, Google [Bot] and 34 guests
