It is currently Wed Oct 14, 2026 4:52 am
 Post subject: Vacuum line harness
PostPosted: Tue Aug 14, 2012 10:28 pm
My precious '75 Dart has what appears to be a vacuum harness. The vacuum lines are glued into "plugs" which attach to the various components in the vacuum system. Does anyone know where I would be able to acquire a replacement from?
Thanking you in advance,
Clyde
PostPosted: Tue Aug 14, 2012 11:04 pm
There are a few components that have moulded multi-hose connectors on them from the factory. Most of the vacuum connections are single-hose. There is zero availability of reproduction or otherwise new vacuum harnesses; you will have to make your own from commercially-available vacuum hose. Plain black stuff is factory stock, or you can get high-tech silicone hose in numerous colours. The original-type connector plugs are not available.
Users browsing this forum: DuckDuckGo [Bot] and 11 guests
