It is currently Tue Nov 10, 2026 7:42 am
Post new topic  Reply to topic  [ 176 posts ]  Go to page 1 2 3 4 5 … 12 Next
PostPosted: Thu Aug 16, 2012 9:52 am
hey guys i have info coming from wilcap that they have an adapter for the slant six to a chevy 200R4, it comes with everything...
waiting on pics and price... hopefully today!
will update as soon as i know something...
1965 Plymouth A/FX 512ci (under construction)
1968 Dodge Dart SL6 14.25 @ 91.5 1.91 60'
1973 Dodge Dart SL6 Stock
Killer Bee's Member Since 09'
http://www.forabodiesonly.com/mopar/sho ... p?t=128702
http://www.youtube.com/user/805moparkid
PostPosted: Thu Aug 16, 2012 10:06 am
Car Model: 64 Valiant
Pat is a great guy, and is good to deal with. Its also nice he stepped in and is preserving a cool vintage hotrodding icon like Sharp/Wilcap.
PostPosted: Thu Aug 16, 2012 4:10 pm
Now that maybe an alternative for us po' folks, that cant afford to go back stock, or has the know how to do all the other kind of swaps... (and no i am not actually a chebby guy :D )
MRO....
Cheap, Fast, Reliable.... Pick 2...
PostPosted: Fri Aug 17, 2012 6:48 am
here is a link to the post on FABO of the pic and email he sent me...
here ya go guys!
"Ed: We have done the Slant 6 to the Chevy auto but it has not been a popular adapter. Price is $650 with flexplate, hub spacer, fasteners, instructions and of course the plate. Uses the later SB Mopar starter Not included and needs to be modified slightly). Photo attached.
Thanks and spread the word."
http://www.forabodiesonly.com/mopar/att ... 1345211184
PostPosted: Fri Aug 17, 2012 10:42 pm
That is great news! I called Wilcap a few months back and they said that others made this and that I should call around. I turned up nuttin back then and never called Wilcap back.
I am looking at using this trans on at least one upcoming swap.
Should we try to gauge interest for some sort of group buy? I am in for at least one, maybe two. The price may go down.
Thanks again,
PostPosted: Sat Aug 18, 2012 1:59 pm
Is it physically smaller/lighter than an A-500?
PostPosted: Sat Aug 18, 2012 3:00 pm
Yes, and parts are plentiful.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Sat Aug 18, 2012 6:59 pm
Thanks again,
I would be interested if a group buy with a better price could be arranged.
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
PostPosted: Sun Aug 19, 2012 6:08 am
aftermaket suport is great becuase of the grand national and there are some guys that bolt them to bigblock BOP,cadillac aswell so a good trans to use in a street/strip car. just a little longer than a 350 turbo trans to
1980 Aspen 4 speed
PostPosted: Sun Aug 19, 2012 11:56 am
Yes, this looks like a very nice swap. Does anyone have a preferred source for these trannys or a hi perf rebuilder?
The A500 is just huge and heavy and not such a great trans. Mine has been holding up to 300+HP drag passes, though.
PostPosted: Sun Aug 19, 2012 1:35 pm
Ouch. Maybe parts gathering for the OE stuff isnt so expensive after all.
MRO....
PostPosted: Mon Aug 20, 2012 9:07 am
If gas prices start to creep up again, this might be a good option for improving fuel economy. The Gear Vendors overdrive adds a 0.78:1 gear ratio and they claim a 22-28% (say 25%) improvement in fuel economy at highway speeds for a cost of $2795.
Assuming I get 23 mpg (Imperial) or 19 mpg (US) and gasoline costs $1.30/litre ($4.92/US gallon), a 25% increase in fuel economy for a cost of $2795 has a payback of 54,387 miles for the GV overdrive.
The 200R4 gear ratios compare with the A904 (early & wide ratio):
  • 1st - 2.74 vs 2.45 vs 2.74
  • 2nd - 1.57 vs 1.45 vs 1.54
  • 3rd - 1.00 vs 1.00 vs 1.00
  • 4th - 0.67
It looks like the 200R4 has comparable gear ratios as the later wide ratio A904 with a much higher OD ratio than GV. I would expect that it should also offer an even better fuel economy improvement over the GV overdrive. My Barracuda has 2.76:1 axle & P195/75R14 tires and it runs around 2500 RPM @ 60 mph but should run at 2185 RPM locked-up. A 0.67:1 overdrive would drop that to 1464 RPM, which is around where my 5.7L 02 Camaro cruises on the highway.
Assuming I get 23 mpg (Imperial) or 19 mpg (US) and gasoline costs $1.30/litre ($4.92/US gallon), a 25% increase in fuel economy for a cost of $1500 (WAG for adapter & tranny) has a payback of 29,188 miles for the 200R4.
PostPosted: Mon Aug 20, 2012 11:28 am
Thanks for the calculations and thoughts, Frank.
My real world experience with the A500 lockup was that fuel economy is 2-3 MPG better vs. a similarly geared 904 (non-LU). I would call this 10-15% and no better (mild/medium performance 150-180 HP engine). Going from a 904 (non-LU) to my T5 manual is worth 15-20% in MPG (250 HP engine).
The GV folks are smoking crack if they think a 0.78 OD with no LU will get you 25%. I'd say 5-10% would be more like it, IF you did not change your rear gear (say 3.23 and then with OD you get 2.52).
I am looking at the 200-4R as a way to put a well supported OD+LU into my new 64 Valiant, and if that works well, maybe replace the huge, heavy, and poorly supported A500 in the 68 turbo Dart.
PostPosted: Mon Aug 20, 2012 11:37 am
I like where this is going... :wink:
Hey Doc!
We need to add "Swap in a 200-4R" to the "Road Trip List" for when I come and get that '61 Valiant Wagon... :wink: :lol:
PostPosted: Mon Aug 20, 2012 2:22 pm
Art Carr transmissions, did a artical in Hot Rod all about the 200R4 and why he likes them better than the 700R4. This was a few years ago but may be in their arkives. ?
