It is currently Tue May 19, 2026 10:45 am
Post new topic  Reply to topic  [ 518 posts ]  Go to page Previous 118 19 20 21 2235 Next
PostPosted: Mon Aug 20, 2012 7:18 pm
Go for it! You don't need a different coil.
PostPosted: Mon Aug 20, 2012 9:07 pm
Thanks Dan! This is next on my list after getting my 64 dart back together. I want to make sure it runs correctly with the stock ignition first.
My only other concern is to make this conversion look as "stock" as possible.
64 Dart GT - 225
PostPosted: Tue Aug 21, 2012 9:52 am
Sorry to bother again but could I also use the module from this blazer as well? I thought I read on here that it's not recommended but see over here were you mention it will work fine.
I guess the down side would be getting a replacement if the module goes bad.
64 Dart GT - 225
PostPosted: Tue Aug 21, 2012 5:26 pm
Yah, as you wish. There is an advantage to the 8-pin module; see this thread on another board. The linked computer dingus is certainly interesting, but I'm not jumping on it because there's something much better in the works, not too long in the future. Can't say more than that...
...yet.
PostPosted: Wed Aug 22, 2012 2:51 pm
Hmm...very interesting. Looking forward to hearing more about it. Thanks again for the help!
64 Dart GT - 225
PostPosted: Fri Dec 14, 2012 5:52 am
I am building up the parts needed slowly here and there for my hei swap. Duster Idiot recurved a EI dizzy for me and I have a coil bracket from a ford truck and the MSD coil from same truck.
I did a search and didn't see this idea brought up maybe its has and I missed it.
I started to think about the plug wires. Instead of doing the magnacore wire set would it be possible to use a set from a ford 300 4.9L? I like using off the shelf items when ever posible on wear items. Any one know if it would not work or any thing I am over looking?
PostPosted: Fri Dec 14, 2012 7:17 am
The 4.9 set has nice plug boots[/quote] and the lengths are good
1960 Seneca 225 turbo soon to be EFI
 Post subject: Hei
PostPosted: Fri Jan 18, 2013 7:19 am
Is the ICM still used and in the same way?
If only I had the time to do what I want to do instead of what I have to do!
PostPosted: Mon Jan 21, 2013 2:13 pm
does anyone have a part number for the four prong relay plug?
1966 Plymouth Valiant, 225, 3 on the tree, 8 1/4 3.21 sure grip, hyperpac, holley 650dp, holset h1c
PostPosted: Wed Jan 23, 2013 4:55 pm
nevermind, found one on ebay
PostPosted: Wed Jan 30, 2013 11:39 pm
Hi, just about to do this HEI 4 pin / high output coil thing, but are getting stuck which components to order.
Can someone help me out with how to identify the right quality 4 pin module, as I will be ordering online offshore. Is it a particular manufacturer / country of manufacturer, that I should be looking for, or are all modules pretty much the same.
Looking at the Summit website and their MSD Streetfire module 5596 that looks like a standard 4 pin module, BUT is described as a multi spark. Is this an error, if not do the other modules from different manufacturers do this too, or are they special on their own.
Also getting stuck on the coil to purchase. Many websites just describe their coils as high output. What is a good output to be looking for?
Looks aren't important, but the msd 2 coil will be in keeping with the original look. Are these ok to use, and will I be disadvantaged that much compared to using a transformer coil.
Cheers
Peter
1967 VC Valiant
PostPosted: Sun Feb 03, 2013 6:59 pm
could someone elaborate as to what goes where when using this relay. please.
PostPosted: Sun Feb 03, 2013 7:02 pm
Have a look at the sticky above (under Electrical section)
HEI electronic ignition retrofit, How to... Everything you need is covered there
1967 VC Valiant
 Post subject: Recent conversion
PostPosted: Sat Feb 16, 2013 3:56 am
Thanks to all that have added to this thread. It is getting lengthy but well worth the read if you are doing the conversion. I am just going to add my two cents and include a couple of pics. It has been a little challenging because of the anal nature in which I go about doing things. The conversion itself would have been simple had I not placed so much importance on making it look as natural in the vehicle as possible. As it turns out it ended up pretty much where everyone elses does except it is closer to the front of the vehicle, and yes the hood still closes. I was a bit confused by how much emphasis was placed on the ground wire for the module. In my case the module is mounted to a piece of aluminum angle which is attached to a clean paint free surface with SS sheet metal screws. I dont see how I could get a much better ground. In any event the job is complete, along with a complete rewire of the engine compartment as well as a fuel line modification. I have a few issues to work out but it cranks right up so thats a good start. Here are a couple of pics..http://s1305.beta.photobucket.com/user/ ... ds,%20Mark
 Post subject: Mod
PostPosted: Sat Feb 16, 2013 3:57 am
by the way this is a 1964 Valiant
Users browsing this forum: Amazon [Bot] and 11 guests
