It is currently Sat Jun 20, 2026 12:15 pm
 Post subject: help
PostPosted: Fri Nov 07, 2003 9:24 am
I put the g.m ele. ign in my 70 dart with a dist from a 79 aspen and the car is in the shop and they say that the hold down i have isnt the correct one i got it off the car i got the dist?? whats going on what did everyone else use??
thanks
PostPosted: Fri Nov 07, 2003 9:31 am
tell your mechanic to pull the hold-down off your stock distributor and use it, assuming you had one to start with.
-S/6
PostPosted: Fri Nov 07, 2003 9:51 am
Thanks :D
PostPosted: Fri Nov 07, 2003 10:57 am
Jared,
I was really surprised to see that hold down when I pulled it from the car. all the others Ive seen have the tab with a slot but I figured it should work. or you could just swap the one from your old distributer.
Phil
