It is currently Mon May 25, 2026 6:13 am
PostPosted: Thu Sep 06, 2012 4:39 pm
Ramchargers were from the 80's. The vehicle I saw it in was a state of Tennessee vehicle. 4X2.
PostPosted: Thu Sep 06, 2012 5:07 pm
Car Model: 62 Lancer, 63 D100
Just got home from PicknPull in Chico. 77 Aspen had factory heat shield, with a fresh carb for my 77 Aspen. I snagged them both. The heat shield can go to whoever will do the right thing with it. Let me know. Bruce
61, 62, 63, 64 Valiants
62 Lancer
64 Darts
66 Barracuda
64 D100
77 Aspen
PostPosted: Thu Sep 06, 2012 6:45 pm
If nobody else steps up with intent and means to create a pattern for the heat shield, I'll do it.
PostPosted: Thu Sep 06, 2012 8:01 pm
I would say I would do it, but it would be a lie. I know it would end up shoved off to one side of my workbench next to a pencil and a pad of graph paper and I would keep meaning to do something with it but would never find the time.... :?
PostPosted: Thu Sep 06, 2012 8:44 pm
Car Model: 1982 D150
I have one at home. I could trace it and send it in, problem is, I dont have a scaner big enough...
Slant power!!!
At least I try...
PostPosted: Thu Sep 06, 2012 10:15 pm
Car Model: 1977 B100 Van
Well, I can create a vector file of it and make it available for download, so if shipping it to Canada is not too high, I'm interested.
Dan, with your knowledge you might do a better job than me (like maybe creating a 2 barrel version like Reed suggested). What do you think?
You can try scanning it in parts, with enough overlapping and some registration marks, I should be able to trace a full size template.
(Laying a ruler on the scanner for reference will also help).
Good friend of mine is building a CNC machine. I hope he will be willing to cut a few shields out of an aluminum plate. :)
"Hey, I like that paint job you got. What they call that--sorta a cross between Piss Yellow and Puke Green, ain't it?" -- Bob Falfa
PostPosted: Thu Sep 06, 2012 11:44 pm
I have the factory two piece type off a 1981 truck. I also have made one for a two bbl carb that seems to work well. I do not have the means to copy or fax these but I would be willing to mail them to some one that can copy them. The down side is I would like them back.
PostPosted: Fri Sep 07, 2012 12:51 am
Send your heatshield to Agressive Ted.
The one I had seems to have disappeared.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Fri Sep 07, 2012 8:54 am
Not to get side tracked, but were there ever a heat shield for the Super Six, or would it be of much benefit?
Also to toss this out there, I have a friend with a couple CNC machines, so maybe he'd be interested in doing a small run as well.
'66 Dodge Dart
PostPosted: Fri Sep 07, 2012 9:38 am
"Need them back" is not an impediment as far as I'm concerned.
2bbl version is yes.
PostPosted: Fri Sep 07, 2012 11:35 am
I made a full size pdf of a template created from the photos. I'd gladly post it here if someone would tell me how. Don't know how to post a pdf.
Chinook carrying Gama goat, circa 1983.
PostPosted: Fri Sep 07, 2012 11:43 am
Here are photos of my crude template and pdf printout of same. If you want a copy of the pdf, let me know, I'll be glad to email.
PostPosted: Fri Sep 07, 2012 12:51 pm
Is that to say that there was a factory heat shield for 2bbl slant sixes? Do you have a picture of one or can describe how they vary from the 1bbl shields?
'66 Dodge Dart
 Post subject: Heat shield
PostPosted: Fri Sep 07, 2012 2:44 pm
MLC Duster,
PM sent with address.
PostPosted: Fri Sep 07, 2012 3:59 pm
Guys,
I need an email address if you want a copy of the template. It is in pdf format. Or, better yet, if a moderator could post it for anyway to get--that would be more efficient.
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 5 guests
