It is currently Fri Nov 13, 2026 11:36 am
 Post subject: 8 1/4 gear change
PostPosted: Tue Sep 11, 2012 2:09 pm
Assuming the rest of the axle assembly is in good shape (axles, bearings, etc...), what parts will I need to swap an A-body 8 1/4 rear axle from a 2.2 gearset to a 3.2 gearset? I have a 3.2 ring, pinion, and carrier out of an early 70s Dodge van ready to go, but what else will I need/should I have on hand? Any special tools I will need to get the gears set up right? I have a magnetic base dial indicator, but will I need more?
Thanks.
PostPosted: Tue Sep 11, 2012 6:12 pm
a new crush sleeve ...an air impac to tear apart
PostPosted: Tue Sep 11, 2012 7:51 pm
I'll order up a new crush sleeve, I got the air wrench covered.
PostPosted: Tue Sep 11, 2012 8:22 pm
6 Pack Dart
How about an inch/pound torque wrench dial or beam type.
Richard
PostPosted: Tue Sep 11, 2012 9:15 pm
Torque wrench- check!
PostPosted: Wed Sep 12, 2012 5:47 pm
are there any write ups on this yet? i was wondering how to do it myself
1966 Plymouth Valiant, 225, 3 on the tree, 8 1/4 3.21 sure grip, hyperpac, holley 650dp, holset h1c
PostPosted: Wed Sep 12, 2012 8:46 pm
If anyone has a link to a how-to article on changing 8.25 gears, please share.
PostPosted: Thu Sep 13, 2012 9:42 am
You will also need a large& internal Hex tool to do the Lash adjustment..
I forget the size of the Hex - probably like 1.25" or something...
I made one by getting an old pair of transverse tortion bars off of an FJM body donor car, cutting the bends of of them and then welding the 2 cut ends togther.. it's the correct size hex for the job, and will be a longer than the axle tube.
I am not sure if you can get the spanner wrenches in there like you might use on an 8.75 Setup.
PostPosted: Thu Sep 13, 2012 9:53 am
Uh oh. Thank's Greg. I will have to investigate that further once I get the axle up on my bench and can get a really good look at it.
PostPosted: Thu Sep 13, 2012 9:58 am
Car Model: 64 Valiant
Any pics of your tool you made Greg. Also pm sent.
PostPosted: Thu Sep 13, 2012 10:40 am
I forgot I had previously found this writeup on a Jeep site:
JEEP link
Looks like Randy's Ring and Pinion sells the adjuster tool for $65.
PostPosted: Thu Sep 13, 2012 5:31 pm
a bent screwdriver works if caps not bolted tight,once set tighten caps and install keepers/screw
 Post subject: Lol...
PostPosted: Thu Sep 13, 2012 5:48 pm
Old C-body torsion bar works good too...
:wink:
PostPosted: Thu Sep 13, 2012 6:14 pm
so i read the write up and seems pretty good. what would be the difference between that and a rear with a sure grip?
 Post subject: Re: Lol...
PostPosted: Fri Sep 14, 2012 3:58 am
:wink:
YES you are right... I forgot...
' round these parts Old Junk c bodies / parts are getting scarce, but Plenty of F/J/M cars left rotting from 1989 still ' round here. :D
Users browsing this forum: Ahrefs [Bot] and 1 guest
