It is currently Fri Oct 09, 2026 5:50 pm
PostPosted: Thu Sep 13, 2012 6:44 pm
My coil get really hot and I've been told the coil should only be "warm" to touch and if its not, there must be some short somewhere in the wiring.
Is this true? should I be concern?
Thanks
Syed
Cars: 1966 Dodge Dart 270 Convertible,
1990 Alfa 164 Twin Spark
1980 BMW 735i 5-speed
http://www.weddingcar4u.blogspot.com/
 Post subject: Coils
PostPosted: Thu Sep 13, 2012 7:26 pm
I am assuming your car and engine are stock. I wouldn't worry about it.
It is amazing how much abuse the stock oil filled coils can take. SL6Dan can quote life expectancy. Dan is our electrical specialist.....however, keeping the coil cooler goes along way to extending their life. I moved mine up to the fender away from the heat of the block to provide better cooling and longevity. I ran the stock coil that way for years before trying a HEI style coil.
If you have bypassed your ballast and feeding a stock coil a full 12 volts.....that will make them run pretty toasty! You need to keep the ballast in the circuit unless you run a 3 ohm coil, or have done the HEI conversion, then full voltage is fine.
Click on the red link be low my name to view pictures.
 Post subject: Re: Coils
PostPosted: Thu Sep 13, 2012 8:31 pm
Here is my current setup (note coil on the inner fender)
and here is DIY electronic ignition kit im using :
http://www.jaycar.com.au/productView.as ... TID=965#11
Syed
Users browsing this forum: Google [Bot] and 29 guests
