It is currently Mon May 25, 2026 7:21 am
 Post subject: removing old stickers
PostPosted: Sat Nov 08, 2003 4:26 am
I've removed all but one sticker from the body and glass of my truck. I bought some of that old sticker remover solvent stuff, but it only works on the glue that's left behind after first removing the sticker. The one that's left is so old and cracked that I can't grab hold of any part of it to start it peeling. I'm afraid to use a razor blade for fear of digging into the paint.
Any ideas?
PostPosted: Sat Nov 08, 2003 5:13 am
Contributor
If the sticker is vinyl, you can heat it with a hair dryer and scrape it off with a piece of wood or plastic that's softer than the paint.
PostPosted: Sat Nov 08, 2003 5:19 am
yeah, I thought about a blow dryer. It's one of those square State Farm Insurance stickers. It's really thin and I'm not sure if it's vinyl or not. I'll give it a shot.
PostPosted: Sat Nov 08, 2003 8:31 am
If it's on glass - a little carb cleaner works great... be careful, it will also remove paint and jack up rubber...
My 63 Valiant
http://www.readersrides.com/rides/class ... aliant.htm
<img src="http://www.readersrides.com/slant6-02.gif"/>
PostPosted: Sat Nov 08, 2003 10:28 am
Spread some peanut butter on it and let it sit for a couple of hours. Have been told this is one of the best methods for sticker removal.
PostPosted: Sat Nov 08, 2003 1:53 pm
3M decal remove - NAPA sells it and it works great. Will not hurt paint.
Tom
 Post subject: hair dryer
PostPosted: Sat Nov 08, 2003 2:41 pm
If you use the hair dryer, be sure to keep it moveing. If you leave it in the same spot to long it will bake the paint...
PostPosted: Sat Nov 08, 2003 3:23 pm
!!! you're kidding, right?
PostPosted: Sat Nov 08, 2003 3:50 pm
No i'm not kidding.: 8)
