It is currently Mon Jun 15, 2026 3:57 am
 Post subject: roller rockers
PostPosted: Sat Nov 08, 2003 5:55 pm
hey y'all, anybody make roller rockers for the slant? me and a freind are planning a couple slant six build-ups, and we're wanting some roller rockers for them.
72 D100, Project "RT 100"
89 Lebaron,aka "The Red Baron",supercharged 3.0 5-spd project
84 D50 Sport, 2.6 5-spd, Weber carb
84 Shelby Charger, turbo project
71 W100 big block 4x4 project
PostPosted: Sun Nov 09, 2003 12:28 pm
The Cox Brothers have them in stock usually. 614/268-9920 :shock:
PostPosted: Sun Nov 09, 2003 8:47 pm
cool, thanks.
PostPosted: Sun Nov 09, 2003 8:52 pm
I believe Doc has used them on his race engine. Search for using roller rocker or something similar to see his pictures. I know he had to use an oil spray bar to keep them from burning up.
PostPosted: Sun Nov 16, 2003 3:30 pm
why, do they cause oiling problems for the top end?
PostPosted: Sun Nov 16, 2003 8:05 pm
They have been known to not oil the roller tip enough on the street, and that causes stem problems.
PostPosted: Sun Nov 16, 2003 8:17 pm
The Slant works against us when it comes to roller tip rocker arms. The tip (and the valve stem) are the high point so it is hard to get oil up to that spot.
As noted, I install an oiler into the valve cover and pour oil right on the tips.
http://www.dutra.org/pictures/engine/pa ... -oiler.jpg
PostPosted: Tue Nov 18, 2003 5:47 pm
cool, thanks a lot, guys.
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
