It is currently Sat Nov 14, 2026 2:25 am
PostPosted: Tue Sep 18, 2012 1:14 pm
can the bearing retainer be swapped over from a od to a four speed and the non od 833 be used in its place? my trans locked in 2nd now and is flat worn out
1980 Aspen 4 speed
PostPosted: Tue Sep 18, 2012 1:39 pm
Err... just add an adapter ring to make-up the size difference.
 Post subject: Yep, or...
PostPosted: Tue Sep 18, 2012 6:08 pm
If you are lucky enough to find a 1975-1976 A-body or 1976-1980 F body with a 3 speed, the unit will have an input bearing retainer that will bolt to the 833 and fit the OD bell...pretty much a tough to find item, and Wildcat/Brewers want some $$$ for one if in stock.
PostPosted: Wed Sep 19, 2012 8:39 pm
any one got one?
1980 Aspen 4 speed
PostPosted: Fri Sep 21, 2012 7:23 am
Isn't the overdrive bearing retainer bigger than the regular 4 speed retainer? I put up an ad on FABO last year and was able to trade a guy mine for an OD retainer. Put up an ad over there and see what you can get.
 Post subject: But...
PostPosted: Fri Sep 21, 2012 7:02 pm
Yes but there are things that have to happen:
1) The A-833OD uses a larger diameter bearing retainer...but the input bearing is the large 308 style bearing that you would find in the 440/6pak and hemi 18 spline boxes...
2) The standard A-833 and most 3 spds, use the smaller 307 input bearing so their retainer bolt pattern is much smaller...
So the choices are:
Sleeve like Doc has shown.
1975+ A-230 bearing retainer (small bearing bolt pattern with the 5.125" retainer diameter).
