It is currently Sun Jun 14, 2026 10:07 am
 Post subject: what carb would this be?
PostPosted: Fri Oct 17, 2003 3:23 am
!983 Dodge D-150 slant 6 225 CID 2 bbl no vacuum advance on distributor. I know it is a Holly 2 bbl could it be a 2280 ? Does it have have ported and regular vacuum pickups?
Thanks.
Fran
!983 D-150 2 wheel drive with 225 CID 435 4 speed. Long bed
PostPosted: Fri Oct 17, 2003 5:39 am
According to these drawings, it has venturi and manifold vacuum; but, no ported vacuum...
http://www.slantsix.org/articles/choke- ... 0-info.jpg
http://www.slantsix.org/articles/choke- ... -info4.jpg
BTW, they come from the site here: (thanks to Doug et.al. :) )
http://www.slantsix.org/articles/choke- ... adjust.htm
My truck is a Frankenstein creation
Built from the dead carcasses of others
And brought BACK TO LIFE!
 Post subject: No Vacuum Advance...
PostPosted: Fri Oct 17, 2003 10:40 am
Distributor has no vacuum advance and the carb may not have the correct idle mixture screws, sound like a lean burn carb to me...
PostPosted: Fri Oct 17, 2003 11:32 am
I can't speak for what's on sailit2000's truck; but, an '83 D-100 would have come from the factory with lean burn (or an EFC with a 62x0 carb if it was a Cali. car).
 Post subject: R U sure it's a 2bbl ?
PostPosted: Sat Oct 18, 2003 9:37 am
I have a '83 W-150 .It had the leanburn before I tossed it in the trash (where it belongs), and the carb is a 1bbl (Holley 2245) , so unless you've actually removed the carb and know it's a 2bbl....
I used to have a '78 D-100 with a /6 and the 2bbl, but that was a Carter (and it was horrible).
 Post subject: Whoops...
PostPosted: Sat Oct 18, 2003 10:56 am
Holley 1945 is a one barrel, Holley 2245 is an emissions carb for the 360-2V and 400-2V in 1974+ Road Barges (It replaced the 2210...)
PostPosted: Sat Oct 18, 2003 1:13 pm
Ooops! :oops:
my bad. I got the last two numbers right.
Better sleep with earplugs from now on....
to keep any more of my marbles from rolling out :?
PostPosted: Sat Oct 18, 2003 5:46 pm
:wink:
PostPosted: Sun Nov 09, 2003 9:29 pm
If your distributor has no vaccuum advance then it is the ESC/Leanburn system, the stock carb/manifold combo could have been either a 1bbl or 2bbl in 83. Mine came with the 2bbl setup on it, but when I got it there was a Holley 2280 in place of the Carter bbd that should have been there. As far as I can tell it was off of a 318, jetted much too lean for the 225 and it ran very poorly to be nice. The 1bbl that year would have been a Holley 1945(?) carb. Either in stock form work well. From what I understand the 2280 was installed on the slant 6 from the mid 80's to end of production. If you have the Holley 2280 on your slant, I would change it to the Carted BBD instead. Much better carb with more power than the Holley.
