It is currently Tue Jun 16, 2026 5:25 am
 Post subject: Oil Pump
PostPosted: Mon Nov 10, 2003 10:09 am
Car Model: 71 Dodge D100 64 Plymouth Valiant Wagon
I'm looking at changing my oil pump due to leakage. For $65 (as opposed to $35) at NAPA I can get a high performance oil pump.
Is that recommended? What should I be looking for/watching out for?
Thanks, Joe
Joe Hoppe
71 D100 225 Super Six 727 AT on 2008 Crown Vic CopCar frame
64 Valiant Wagon 225 904 AT 3:23 8.75"
 Post subject: Read this:
PostPosted: Mon Nov 10, 2003 10:45 am
Read this:
http://www.slantsix.org/articles/oil-pu ... report.htm
---Red
PostPosted: Mon Nov 10, 2003 10:51 am
The general consensus here seems to be stick with the stock pump. Hi-performance pumps seem to put too much stress on the oil pump drive gear, leading to pre-mature oil pump gear or cam gear failure.
I currently am running a hi-volume pump. It provides 40 psi at hot idle, and 60 psi at anything over 1200 rpm (this is on a rebuild with 2.5 miles---my bearings are still tight) When I pulled the pump for my rebuild, it had about 20,000 miles on it, and the pump gear was worn about 50-60% :shock: . Cam gear was not showing any signs of wear.
As long as you are getting the 'rule of thumb' 10 psi of oil pressure per 1000 rpm, the stock pump will be your best, most reliable bet.
-S/6
The "Silver Bullet"
87 Ram D150
 Post subject: oil pump gears
PostPosted: Mon Nov 10, 2003 2:54 pm
Daddiojoe...
Read this also:
http://www.slantsix.org/forum/viewtopic ... atch#22164
Try a PM to Doc and see if he has any gears left from the batch he had hardened awhile back. A bunch of us stocked up at that time for our future needs.
---Red
 Post subject: Thanks!
PostPosted: Tue Nov 11, 2003 9:03 am
Red and Super6--
Thanks for your help. Glad to know I can save a little $ and it won't effect things at all.
Those articles were really helpful, too.
Joe
Joe Hoppe
