It is currently Mon May 25, 2026 4:39 pm
PostPosted: Sun Sep 30, 2012 8:54 am
Yep, it goes to me. I was getting ready to button up my k-member swap and went to put in the battery. You guessed it, both battery cables are black and I installed it backwards. I should have stopped to think when I saw sparks coming from the battery terminal but my wife was waiting for the car to go shopping and I wanted to get her done.
Well anyway, I hooked it up backwards and tried to start the car, but of course it didn't work. I get out and realized that I AM AN IDIOT!!!
The battery was drained, so I dropped in another one, and the car started right up. And I can drive it around, it starts fine every time. But that's where my luck ends. The headlights are very dim and I think there is something wrong with the charging system because with the engine running I'm only getting 12.49v across the battery terminals.
What should I check for? And how? I did a search and found that something similar has happened to a fellow forum member TWO YEARS AGO. I think in that thread Dan suggested the diodes in his alternator were fried.
-how do I test an alternator? I think the one I have is stock
-is there anything else that I should test for? How do I go about it? I have a voltmeter, and a test light.
Looking forward to your replies, bracing myself for your jeers.
Thanks, Mike
1966 Dart Wagon
1967 Volvo 122s
1989 Ford F350 4x4
PostPosted: Sun Sep 30, 2012 8:58 am
Alternator's toast—its diodes are cooked. You'll want to replace the alternator and voltage regulator. That should be the extent of the damage.
PostPosted: Sun Sep 30, 2012 10:33 am
Thanks Mr. Dan
1966 Dart Wagon
1967 Volvo 122s
1989 Ford F350 4x4
PostPosted: Sun Sep 30, 2012 1:43 pm
Don't feel too bad I see it all the time at work. I work at a toyota dealer and the absolute most fun is when someone does it to a prius. Hook them up backwards and you can blow the power inverter. It's only about $2000 to replace one on a prius. Most modern stuff will pop the alternator fuse when hooked up backwards.
PostPosted: Sun Sep 30, 2012 2:52 pm
:shock: "both battery cables are black"
1964 Dart GT
PostPosted: Sun Sep 30, 2012 3:40 pm
Car Model: '23 T-bucket
Ummm.....yeah, Mikey....you might want to correct that at the earliest opportunity. Other than that, you just proved you're a human. :lol:
Roger
PostPosted: Mon Oct 01, 2012 5:23 am
Roger
Yes, I will do that.
Thanks all.
1966 Dart Wagon
1967 Volvo 122s
1989 Ford F350 4x4
PostPosted: Mon Oct 01, 2012 12:02 pm
I know from personal experience, if you have a completely discharged battery on your bench & you hook up the charger backwards for a few hours, it WILL take a charge- sort of. (Huh? why does this thing read NEGATIVE 8.5 volts?- dohh!)
If you reverse polarity when you try to jump start another car, the jumper clamp will try to weld itself to the spot you hooked to- (I broke it loose before anything blew up)
I once had a Supra Turbo towed in after AAA tried to jump start it- the alternator fuse WAS blown, but so was the $900 ignition module- I guess they had the ignition on when they hooked up backwards.
Point is, you live & learn (betcha never do that again :wink: )- damage was done but the car's still there.
63 Valiant Wagon
225 - 4 bbl
PostPosted: Mon Oct 01, 2012 3:56 pm
Hey, Mopars (and many other cars) USED to have positive ground systems: just pretend you mistook your car for a 1930-something model.
Then again, I guess that wouldn't be much of a face saver, now would it.
As you were...
obliquely-inclined state of mind
