It is currently Sat Jun 13, 2026 12:59 pm
PostPosted: Mon Oct 08, 2012 2:38 pm
Three on the Tree
hi Bear R.-here.just wandering if i need a gasket sealant for my water pump?its a chrysler water pump .it has a gasket under a metal plate that does not come off do to the blade.any ideas here.or,do i just bolt it on?thanks everyone God Bless you all,Barry.
1967 Dodge Coronet 440. 225cid. 3 speed column shift.radio delete
PostPosted: Mon Oct 08, 2012 5:53 pm
I usually use the grey water pump and thermostat sealer from Permatex. Just smear some (lightly) on the gasket that mates to the block.
PostPosted: Mon Oct 08, 2012 6:41 pm
It uses 2 gaskets, the one between pump and plate will come off, its a little tricky to fish it around. I personally used only sealer between block and gasket (block had some pitting)
