It is currently Sun Jun 07, 2026 12:36 am
 Post subject: Erson cam ??
PostPosted: Sat Oct 06, 2012 9:22 am
Does the Erson 280/270 or 270/270 cam use the larger Chrysler lobes or do they rely on the smaller chevy lobe and how doe they compare in perfomance to the comp 264 cam(currently running this cam-not impressed). Thank you.
HyperValiant
1960 Hyper-Pac Valiant(rolling test-bed)
1963 Valiant V2OO(Son's summer project,- he just turned 15 :-) )
1972 Valiant 4dr(Daughter Kelly's repair in progress)
1974 Valiant (v8) daughter Kelly's work in progress
PostPosted: Sat Oct 06, 2012 10:43 am
I went from the Comp 264 to the Erson 280/270. There is a world of difference. You will like it.
Much more torque over a much wider range.
 Post subject: Yep...
PostPosted: Sat Oct 06, 2012 10:54 am
Depending on your choice of lobe separation results may vary, but if you buy the over the counter grind you will have torque over a broad range like Sandy stated, it will not have a problem reving to 6200 rpm and you will have low end grunt as well as the engine pulling all the way up to the top end. I have run this cam with 10:1 SCR and a clifford Hyperpak intake it pulled great in a heavy duster and was very street driveable.
With an OD tranny and 3.55's it didn't have a problem doing a mid 16 at the track and still drove home at 24 mpg highway(long trip)...averaged 21 mpg highway (short trips to work).
I'm currently running it in another duster with an offy intake smaller carb and single large exhaust, I think I will go back to duals on that car to pick up more power but it doesn't have a problem grunting through the gears.
PostPosted: Sun Oct 07, 2012 9:49 am
That is a great question!
I have been wondering the same thing. Thanks for the input on driving characteristics.
Another question.
Did anybody advance the cam? or did you install it straight up?
PostPosted: Sun Oct 07, 2012 11:35 am
Another question.
X2 as I'll also be looking for a cam.
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
 Post subject: Advance
PostPosted: Sun Oct 07, 2012 4:21 pm
Another question.
The cam I got was ground 4 degrees advanced and I installed it that way.
Would be curious to see if anyone went 108 LSA with a 102-101-ish centerline.
-D.idiot
PostPosted: Sun Oct 07, 2012 4:37 pm
Site Admin
The Erson had the larger chrysler lobe. Not sure if they still do with the company selling and moving. All depends on where they get the blanks. Ask them. I haven't purchased an Erson for at least five years.
CJ
PostPosted: Sun Oct 07, 2012 5:54 pm
Dit oh!
PostPosted: Mon Oct 08, 2012 12:12 pm
Thanks fellas,that info helps alot. On a related note,what mods have been done to your cylinder heads.I have the Engine builder 170/144 valves and 340 springs and plan on doing my own port work from what i have learned on the site. Thank you HyperValiant
PostPosted: Mon Oct 08, 2012 5:11 pm
!.72 intake 150ex Chev valves + springs....pocket ported like a chev....radiussed chambers ...60 off the head .....100 off the block
9.25 scr
 Post subject: 2 ways to sunday...
PostPosted: Mon Oct 08, 2012 5:28 pm
1.70/1.44 SI slant six valves, back cut with 3 angle valve job, pocket porting and gasket matching for small runner Clifford Hyperpak intake...10:1 SCR...
New combination 10:1 SCR, 1.70/1.44 Enginebldr valves and springs, same type of porting above using an offy manifold and small 4 barrel.
PostPosted: Mon Oct 08, 2012 6:15 pm
Car Model: Toad Wagon
I'm also presently running an Erson 280/270, clocked at 102.
The lobes on mine are the same width as the stocker.
Ported & polished (I do my own), 1.70 & 1.44 Stanwood (Engnbldr) valves, .110" off the head, fresh "stock" Erson springs, stock "light" retainers, lightened stock rockers, stock dumbells & pushrods, and notched the stock slugs for the valves.
Still fussing a bit with lash settings, but she's solid & strong right up through 6000, with no float.
(when I want it ..... I shift at 5400 usually)
Car's a middie @ 1420 lbs (see Flyin' Brick in my sig's photo links), running three 1 3/4" SUs.
Can light'em up in any gear at will, due mostly to running our HA/GR class's 6" street tread bias plies.
Sex, drags, and rock & roll.
Dick, 225% crazy.
PostPosted: Mon Oct 08, 2012 8:43 pm
hey old6rodder that thing is awesome. do you have any video of it in action?
PostPosted: Tue Oct 09, 2012 4:26 pm
Not on someone else's thread, I'll post up a link to what little I have over in the Social Corner.
Dick, 225% crazy.
