It is currently Thu Jun 04, 2026 7:50 am
 Post subject: crankshaft damper/pulley
PostPosted: Mon Oct 08, 2012 4:03 am
Adding power steering and A/C to my 65 Cuda. P/S pump located in the stock position, driver side low. A/C hopefully low on the passenger side.
P/S pump and water pump to be driven by a single "v" belt, A/C and ALT to be driven by double "v" belts.
Is a 3 groove "v" belt crank pulley/damper available?
If I were to go with a 6 rib serpentine belt for the A?C, Alt, and bolt the drive pulley to the center of my stock 1 groove "v" belt crank pulley, would that interfere with the dampening function. I beleive so.
Thanks for any comments and suggestions.
Tom
PostPosted: Mon Oct 08, 2012 6:02 am
Yes, there are sheaves that bolt on the front and back sides of the stock damper. Yes, you will have to remove the damper to install the back one.
PM Charlie_S, he does a neat A/C conversion and sells brackets for the Sanden compressor I believe.
PostPosted: Tue Oct 09, 2012 3:56 am
Thanks for the info. I'll PM Charlie and see what we can come up with. I appreciate all the support that is in this forum.
Tom
Users browsing this forum: Ahrefs [Bot] and 10 guests
