It is currently Tue Jun 02, 2026 6:17 pm
 Post subject: Super Six Carb linkaage
PostPosted: Mon Oct 08, 2012 9:46 pm
I've got a supersix manifold, carb and air cleaner, but can't find out what carb linkage will work.
It is going on a 64 Dart 225
Any help appreciated.
Norm :?
PostPosted: Tue Oct 09, 2012 10:18 am
http://www.slantsix.org/articles/supersix/article.htm
PostPosted: Tue Oct 09, 2012 2:38 pm
Your '64 Dart has a rod-type throttle linkage and accelerator pedal. You'll either have to retrofit a cable-type pedal and accelerator cable, or forget the Super Six intake manifold and modify a 1bbl intake to mount the 2bbl carb parallel rather than factory perpendicular and continue to use your existing linkage and pedal. See the parallel 2bbl setup article. Photo documentation of a very well done such conversion is here.
Users browsing this forum: Amazon [Bot], Bing [Bot], hyper_pak and 18 guests
