It is currently Sat Jun 20, 2026 9:01 pm
 Post subject: Are these good? (UCA)
PostPosted: Fri Oct 05, 2012 4:25 pm
http://www.ebay.com/itm/200775821762
Are these good/worth the money? I have been looking for UCA´s for a disc brake conversion and came across this listing on Ebay.
Dart GT -64
Dart 270 -63
Chevy Silverado -86
GMC Vandura -87
PostPosted: Fri Oct 05, 2012 5:21 pm
I wonder where they are made...
PostPosted: Fri Oct 05, 2012 8:02 pm
With a shipping location of miami florida I would expect they were made in a nice 3rd world country south of the us. Most made in china garbage ships out of california. If they are of decent quality that isn't a bad price for arms with BJ's, bushings, and cam bolts. When I went disc I bought RMS arms for $300 and have had poly bushing squeeeeeeeek ever since, but no other problems.
PostPosted: Fri Oct 05, 2012 8:17 pm
In principle I don't object to a Mexican-made suspension part the way I object to a CHinese-made one.
PostPosted: Sat Oct 06, 2012 1:05 am
Read down in the listing. Says not for disc brake conversion.
PostPosted: Sat Oct 06, 2012 1:50 am
Yes I have seen that but what could be different? It is a large balljoint upper controlarm for a 73-76 A-body.
The same seller also has a kit without the cambolts and that listing says nothing about that and its the same partsnumber.
http://www.ebay.com/itm/200775821756
I also found this archived discussion:
http://www.forabodiesonly.com/mopar/arc ... 60006.html
last post is someone who has bought them and he says they are made in Mexico.
I have sent a question to the seller asking about origin of both the UCA´s and of ballljoints and bushings. No answer yet.
Dart GT -64
Dart 270 -63
Chevy Silverado -86
GMC Vandura -87
PostPosted: Sat Oct 06, 2012 7:42 am
See FABO - New Upper Control Arms.
If you need a pair of UCAs, I'd look at getting a tubular UCA. This will get you the ability to adjust the alignment for better caster and camber. If you have the time, wait for a set of OEM UCAs to come up for sale and use the Moog 7103 offset bushings.
PostPosted: Mon Oct 08, 2012 7:11 am
It appears the seller is unaware that disc and drum brake cars used the same UCAs when they went to the large ball joint.
Actually, I don't believe there was any year where disc brakes and drum brakes used different UCAs in a given year. I can't recall, but I think some years had different ball joints from disc to drum.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Mon Oct 08, 2012 7:12 am
I wouldn't risk it. Probably best to buy a used pair from a member here or on FABO and then get Moog bushings for it.
40 year old beat up metal is better than brand new cheap/shiny metal. Plus it says it's not for a disc brake conversion, which makes no sense. It's the lower ball joint that needs to be changed in a disc conversion. The upper control arm can be used on either.
PostPosted: Tue Oct 09, 2012 12:48 pm
Thank you all for your input. After reading that thread on FABO I have decided not to buy them. I will go with som other option like used OEM or tubular.
Dart GT -64
Dart 270 -63
Chevy Silverado -86
GMC Vandura -87
PostPosted: Wed Oct 10, 2012 6:27 am
Site Admin
Why are you shopping for car parts on ebay?
That's like going to the grocery store for a hernia operation. :lol:
2¢
CJ
