It is currently Mon Jun 15, 2026 3:24 am
PostPosted: Sun Nov 09, 2003 9:46 pm
now that I removed my carburetor for a rebuild, should I spray inside the intake manifold with carb spray to clean it? Or use something else? It looks dirty in there.
PostPosted: Wed Nov 12, 2003 10:40 am
Don't worry about the inside of the intake manifold being black, focus on getting the carb rebuilt and working right.
Once the carb is rebuilt and the engine is running well, you can run some fuel system "cleaner" (gas additive) thru it to help remove any intake system varnish.
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 1 guest
