It is currently Sat Jun 13, 2026 1:38 pm
 Post subject: Do i need a kickdown rod
PostPosted: Mon Oct 22, 2012 11:52 am
Do i need a kickdown rod on my 73 dodge dart
All original 36k mile 73 Dodge Dart Custom
PostPosted: Mon Oct 22, 2012 11:56 am
Yes. If you don't have one the transmission will quickly be damaged.
PostPosted: Mon Oct 22, 2012 12:23 pm
If you have an automatic transmission the answer is yes.
If you have a manual transmission, the answer is no.
 Post subject: Thanks
PostPosted: Mon Oct 22, 2012 1:39 pm
Thankyou i just got the two barrel on and running. But i don't have all the linkages where would i find pictures to make one
PostPosted: Mon Oct 22, 2012 2:52 pm
http://www.slantsix.org/articles/supersix/article.htm
PostPosted: Tue Oct 23, 2012 6:13 am
There is always the aftermarket “kick-downâ€￾ throttle position cable solution. [url=http://www.summitracing.com/parts/LOK-KDP-2904U/]Lokar[/url], [url=http://www.bouchillonperformance.com/BPEtkdc.asp]Bouchillon[/url] made of mostly factory like components, similar to Bouchllon’s [url=http://chucker54.stores.yahoo.net/kiccabkit1.html]Mancini[/url], and the junk yard cable & bits from rear drive late 80's early 90's dodge truck.
