It is currently Sat May 30, 2026 7:08 am
PostPosted: Wed Oct 24, 2012 11:10 am
I understand how the standard kickdown linkage works (at least I think I do): it 'pushes' the lever at the transmission back to do its job, and begins to do so at a measured, pre-determined point via the slotted bracket. But whenever I look at Lokar cable setups and the like, the cable, where it's mounted, seems to 'pull' on that lever (see here and here), and it seems to do so in a constant, progressive movement; I never actually see photos of where it connects to the transmission, though, so maybe there's something going on down there I don't realize. Care to set me straight?
J.R.
Tucson, AZ
'68 Dart 270 with a '76-'80 engine
PostPosted: Wed Oct 24, 2012 1:19 pm
The reason the stock uppermost pushrod is slotted (starting in '68) is so that the kickdown linkage, if it jams, cannot hold the throttle open. It's not to provide a "timed" beginning to the kickdown action.
PostPosted: Wed Oct 24, 2012 6:47 pm
Oooooh, okay. That clears that part up. What about the fact the rod pushes the lever, but with all the cable setups I've seen, the cable seems to be mounted below the throttle pivot point, effectively pulling at the lever as the throttle is engaged. What am I missing there? The lever on my transmission is definitely springloaded toward the front of the car (driver's side).
J.R.
Tucson, AZ
PostPosted: Wed Oct 24, 2012 8:47 pm
I have a Lokar kickdown cable on my push button 904.
The cable runs from the carby lever around the top of the gearbox to the back where it is mounted and pulls the lever backwards.
This isn't my gearbox,but this is how mine is mounted.
DRIVE IT,DON'T HIDE IT
PostPosted: Wed Oct 24, 2012 8:50 pm
PostPosted: Wed Oct 24, 2012 9:59 pm
It does not matter whether the cable/rod is pulled or pushed at the top. What matters is that down at the bottom it moves the transmission lever rearward with increased throttle opening.
PostPosted: Thu Oct 25, 2012 12:26 am
THANK YOU, Bucket, for those photos. That's what I was looking for and kind of what I imagined might be the setup, but I don't trust my assumptions, anymore. That info you gave me will prove helpful, too.
Dan, I wasn't being clear: I had yet to see a clear photo showing that the other end of the housing was indeed mounted behind the lever. And like I said above, I thought it might be such a setup, but I was concerned I was thinking backwards or the kit might not be designed for my car. Thank you for your input.
Follow up question: I've read the kickdown linkage from 90s Dodge trucks works just as well. Any experience with this or observations?
J.R.
Tucson, AZ
PostPosted: Thu Oct 25, 2012 5:00 am
True; but:
That cable will work, but you must have properly matched throttle pressure lever, and carburetor throttle shaft cable adapter bracket to have transmission shift & respond correctly at all throttle openings.
PostPosted: Thu Oct 25, 2012 7:08 am
Not trying to threadjack, but I've currently got my kickdown lever on the trans tied back about 1/2-2/3 of the way with a zip tie to keep the trans alive and drive it every day while I get around to fabbing some brackets to mount a cable.
I've got fairly high shift points, but other than that, this shouldn't cause any excessive wear on the trans, should it?
PostPosted: Thu Oct 25, 2012 7:36 am
It's better than no kickdown at all, but it's still hard on the transmission.
See this thread for kickdown options.
PostPosted: Thu Oct 25, 2012 8:00 am
Thanks, I'll get something put together after I come back from Mason-Dixon this weekend!
