It is currently Sun May 17, 2026 9:04 am
PostPosted: Mon Oct 22, 2012 7:08 pm
I have installed my Romac HB with a Lisle (52650)installer, which was a breeze! I have the oil slinger installed and when the balancer is tightened all the way down there is still 5/8" space left(not on the crank)? Is this correct?
p.s.-I haven't installed the water pump yet(tomorrow),to see how the pullys line up.
1964 Dart GT
PostPosted: Mon Oct 22, 2012 11:41 pm
Car Model: 64 Valiant
Yes, thats normal for all engines.
PostPosted: Tue Oct 23, 2012 8:52 am
Great! Thanks for the reply. It looks right judging fron the distance on the back(from the timing chain cover), but it's so much thicker than the stock HB. Appreiate the help!-Dan
1964 Dart GT
PostPosted: Wed Oct 24, 2012 6:52 pm
Worried about nothing. Water pump is on, and lines up perfect!
1964 Dart GT
PostPosted: Fri Oct 26, 2012 5:48 pm
i just hope you measured the snout and had the balancer honed out to spec... they make them tight so they can be hones out for proper clearance...
one guy couldn't get it off with a torch lol...
1965 Plymouth A/FX 512ci (under construction)
1968 Dodge Dart SL6 14.25 @ 91.5 1.91 60'
1973 Dodge Dart SL6 Stock
Killer Bee's Member Since 09'
http://www.forabodiesonly.com/mopar/sho ... p?t=128702
http://www.youtube.com/user/805moparkid
