It is currently Tue May 19, 2026 11:11 pm
PostPosted: Sat Oct 27, 2012 1:54 pm
Since my oil pressure warning light came on and the pressure bypass section of the oil pump looks good, I was going to install a pressure gauge to find out what the true pressure is.
I see that most have a 3/8" fitting but it looks as if the pressure sending unit has a large 5/8", fine thread fitting. Should I find adapters or is there a pressure gauge that will fit?
Does anyone sell replacement oil pressure sending units for the warning light?
Never seen a Valiant I didn't like!
PostPosted: Sun Oct 28, 2012 8:18 pm
Any auto parts store should have the sending unit. As far as the mechanical gauge goes, some kits have a couple diffrent addapter and if yours does not then a good hardware store with brass fittings will do the trick.
But before you change the sending unit check and make sure the wire is in good shape. I found mine became brittle from the heat and was grounding out making my light come on.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 29 guests
