It is currently Wed Sep 30, 2026 11:05 pm
Post new topic  Reply to topic  [ 68 posts ]  Go to page Previous 1 2 3 4 5
PostPosted: Mon Oct 29, 2012 6:29 am
I use the factory vent and a PVC.
11.02 @ 120.56
Chassis dyno
PostPosted: Mon Oct 29, 2012 6:33 am
Bill, i think your deffinetly going to have to vent the block with a fuel pump block off plate and catch can.
Charlie, supposedly, if you ever have a backfire with a turbo motor it can destroy the check valve without you knowing, and one more backfire after that could make an interesting boom
Tyler, 19
72 Dart Swinger /6T
PostPosted: Mon Oct 29, 2012 6:40 am
I am with Shaker223. Stock rebuild with 170k miles. Doesn't burn oil. Makes a little crankcase pressure, but not much.
When I first put it together, I mistakenly plugged the stock breather hose into the intake tract after the turbo. This definitely gave me some problems (dipstick launch and a little oil out in a few places). Unplugged it and no worries since. Granted, I have not seen over 13 psi, and usually limit to 6.5 or 9 psi depending on my whims and cravings.
PostPosted: Mon Oct 29, 2012 8:29 am
When I was running my "Draw thru" turbo, I just had the stock PCV and breather, with no pushing of oil at about 10PSI.
PostPosted: Mon Oct 29, 2012 6:47 pm
This set up worked up to 30psi.
11.02 @ 120.56
Chassis dyno
PostPosted: Mon Oct 29, 2012 11:00 pm
I think it depends on how much blow-by you have as to how much pressure ends up in the crankcase, needing to be vented.
I am going down to Freddie's tomorrow and drive it under ten pounds of boost on the highway for a while.
I'll let you know what happens.
Gettin' interesting!!!! :)
Bill
PostPosted: Tue Oct 30, 2012 4:36 am
I suppose with 10.5:1 and 10 psi I'm getting a fair bit of blow by lol
Tyler, 19
72 Dart Swinger /6T
 Post subject: 10:1 is a lot...
PostPosted: Tue Oct 30, 2012 9:31 am
Yes, you probably are... We're ar 9:1, but not much boost, yet.
Baby steps...
Bill
