It is currently Wed Jun 17, 2026 3:38 am
PostPosted: Sun Nov 04, 2012 4:53 pm
Just wondering how to mount a Slant on a engine stand CORRECTLY. Do I want the center of the engine stand mounting plate centered with the crank? What holes on the back of the block should I use?
1971 Dodge Dart 42k original miles
 Post subject: Search...
PostPosted: Sun Nov 04, 2012 5:11 pm
There are some pics on here posteda while back...
The top two tranny bolt holes are my favorite, with the lowest hole under the oil galley rail, and the "leg" under the starter mounting notch being my other two anchors, using a long bolt with washers and nuts...
PostPosted: Sun Nov 04, 2012 5:26 pm
how could I find the photos
PostPosted: Sun Nov 04, 2012 5:38 pm
Here is the thread with pics. I had the same problem. Slants don't like engine stands from what I can tell.
http://www.slantsix.org/forum/viewtopic ... highlight=
1964 Dart GT
 Post subject: o marks the spot
PostPosted: Mon Nov 05, 2012 4:52 am
I found a 0 on the rear of the block.
I put it ( the 0) as close to the center of the head of my engine stand as i could.
Much more balanced and a lot easier to flip.
Im nott sure if this is the 'correct' way, but it worked for me.
My first attempt at mounting the engine was not real good.
Be careful!
take your time to center the 0 .
Bye
Brendan.
1963 AP5 Valiant 225 PB 904 Stock except extractors & 2 1/4 inch exhaust.
1962 S series valiant 225 PB auto. factory every thing. Full restoration job.
Currently on hold till AP5 is on the road.
PostPosted: Mon Nov 05, 2012 8:47 pm
The slant 6 is nose heavy on most engine stands and most engine stand are made for V8s. You really need one with a H style base instead of the T style. The engine stand that I use would hold 440s quite nicely, but with a slant six it was tippy. Welding a brace across the front of the T worked miracles.
