It is currently Mon Nov 30, 2026 4:42 am
PostPosted: Tue Nov 13, 2012 1:54 pm
Hi all, just curious about who makes the best quality gasket sets for slants? Victor? Felpro? Others? Thanks
 Post subject: Lol...
PostPosted: Tue Nov 13, 2012 7:43 pm
If building a full engine, I typically use the Felpro kit...Recently using higher compression ratios for Race, the Felpro head gasket didn't cut it (10:1 OK, 12:1 no go), but the Victor Reinz head gasket worked like a charm (up to 12:1 OK)... The best head gasket I have used was the Permaseal Aussie gasket, but limited offering here in the USA. Remflex intake/exhaust to head gaskets are worth the money as well in case the manifold is a little off or you are using a mix and match set of parts and unsure if you can true the full set (hyperpak intake and dual exhaust, etc...)
PostPosted: Tue Nov 13, 2012 8:08 pm
I've been bitten too hard and too often by Fel-Pro; they are my last choice. Other than that, I agree with DusterIdiot's recommendations.
PostPosted: Tue Nov 13, 2012 8:27 pm
Thanks guys,I'll go with the Permaseal sets then.Obviously worth the few extra $$
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 2 guests
