It is currently Sun Nov 29, 2026 9:15 pm
 Post subject: Aluminum slant 6
PostPosted: Fri Nov 16, 2012 8:07 am
I have a completely rebuilt aluminum slant 6 from 1962. Runs awesome! Whats its value?
PostPosted: Fri Nov 16, 2012 8:28 am
As they say....
It is worth whatever someone will pay for it. :wink:
The sad thing about engines, they quickly fall into the "used" catagory, soon after you fire it up.
PostPosted: Fri Nov 16, 2012 11:04 am
Where are you located and who rebuilt it?
What are the specs?
PostPosted: Fri Nov 16, 2012 12:24 pm
And how long ago was it rebuilt, has it been run (and how long, and in what) since the rebuild, etc?
PostPosted: Fri Nov 16, 2012 6:48 pm
Special head or star head? Pics and numbers.
I would pay between $200 and $2000 depending on ALOT of details.
I would actually pay more for it apart than together if its good. :D :D :D Mark
PostPosted: Sat Nov 17, 2012 1:32 am
Special head or star head?Pics and numbers.I would pay between $200 and $2000 depending on ALOT of details.I would actually pay more for it apart than together if its good. :D :D :D Mark
But why take one apart that "runs awesome" ? Just wondering. Just after the main parts? (head, block, caps etc)
MRO....
Cheap, Fast, Reliable.... Pick 2...
PostPosted: Sat Nov 17, 2012 2:43 am
[quote="madmax/6"]Special head or star head?
?????????????? :?: :shock:
http://youtu.be/2Y4i4UOLiSA
http://www.forabodiesonly.com/mopar/sho ... p?t=126611
PostPosted: Sat Nov 17, 2012 7:54 am
So you can physically see the actual condition of its innards.
PostPosted: Sat Nov 17, 2012 8:38 am
Aluminium block SL6 engines use a "high accuracy" cast iron cylinder head, those heads had the word "SPECIAL" or a star shape, cast onto them.
PostPosted: Sat Nov 17, 2012 3:08 pm
Is it possible to hear this engine run and where are you located?
PostPosted: Sat Nov 17, 2012 3:59 pm
Thanks doc for the explanation
PostPosted: Tue Nov 20, 2012 3:21 pm
Did this engine sell?
