It is currently Fri May 15, 2026 4:21 am
Post new topic  Reply to topic  [ 18 posts ]  Go to page Previous 1 2
PostPosted: Thu Nov 15, 2012 9:51 am
I think I'll go ahead and try it. Beats dumping coolant out in my garage and driveway.
Easier and cheaper: stop overfilling the radiator. It's not supposed to be full-to-the-brim when cold.
Do you guys know what kind of cap I should use with the bottle?
A cap for a coolant recovery system, such as Chrysler p/n 5207 9880AA.
PostPosted: Fri Nov 16, 2012 4:54 pm
Thanks!
PostPosted: Tue Jan 01, 2013 2:08 pm
Got it installed. Removed the horn and drilled new holes for it. It's a fairly tight fit but there's still enough clearance from the fan and alternator even if the bottle wiggles around a bit.
