It is currently Sun Nov 29, 2026 2:28 pm
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
PostPosted: Thu Nov 22, 2012 2:22 pm
Most machine shops will do just the bottom cut of the valve job if you ask. That way you can port with less money (and risk of nicking a fresh seat) involved...
Brooks
'72 Dart Swinger
'71 Plymouth 'Cuda
Cheap, Fast, Reliable
Pick 2!
PostPosted: Thu Nov 22, 2012 4:51 pm
Car Model: 1964 Valiant V200
That's more or less what they did - just the 70 degree cut and a clean up with the 45 degree. I was going to bring it back after for the final 45 cut and a bit of 30 degree.
PostPosted: Sat Nov 24, 2012 4:17 am
Anybody tried "Extrude Honing" instead of grinding?
I'm thinking of seeing how well it goes to match the ports to a Clifford HyperPak manifold, plus fitting hardened seats and bigger valves of course.
PiD v4.0
'66 VC Valiant Sedan
'67 VC Valiant Safari
PostPosted: Sat Nov 24, 2012 8:05 am
PiD v4.0
You need someone to have the proper tooling, I didn't think anyone still did. CNC porting has taken over most of the common applications.
PostPosted: Sun Nov 25, 2012 3:32 am
Proper tooling is not engine specific for extrude honing. Greg Ondayko on this site had his HP intake extrude honed so you might talk to him.
