It is currently Fri Jun 05, 2026 10:51 pm
Post new topic  Reply to topic  [ 41 posts ]  Go to page Previous 1 2 3
PostPosted: Sun Nov 11, 2012 1:22 am
Toyota 8" truck axle has a removable center section and they're strong.
I believe the 2wd version is 5x4.5 (and maybe later 4wd)
PostPosted: Tue Nov 13, 2012 10:18 pm
Back to the ferd 8.8, if i am thinking correctly they dont have a drop out "chunk" either.. the ford 8" or 9"....
That's probably right, thanks. It's also probably irrelevant, though, since the likelihood of my polluting my Dart with Furd parts - - oh heck, check my earlier ramblings in this thread :lol: :lol: ...
Thank you most kindly for the suggestion. But, if I'm that reluctant to stick a Furd axle under my Mopar, what makes you think I'd use a foreign one?
Folks, I truly do appreciate all the comments and suggestions, even those I've rejected out of hand. I'm right about 99% decided to go with front disk brake kit with new spindles and upper A arms and the same vendor's graphite complete front suspension kit. Will be going to 4 1/2" bolt pattern and 15" wheels painted blue to match the car for kind of a sleeper look.
Just a couple more questions, haggling over a couple of details, then find an installer. Please be so kind as to wish me good luck!
ATB
BC
PostPosted: Tue Nov 13, 2012 10:54 pm
We all wish you the best of luck and want to see as many mopars on the road. I personally would be happier to see an old mopar on the road with some other brands parts on it than not see it on the road at all. I hope the best for you and that it all works out.
There is still a problem with the title of this thread asking for logical and cost effective parts. No way is new spindles, A-arms, and "Poly" bushings fall under that statment.
PostPosted: Wed Nov 14, 2012 2:20 am
Mike, thanks for the kind words. I, too would rather see old mopars out there even if they have another brand's parts in them. But I'd rather that my mopars are darn near all mopar. To me, it's kinda a slippery slope deal. If it's OK to put a Ford axle under a mopar, why not a Chivvy engine?
Maybe I lean more to logical. My idea is to replace the 49 year old parts with new ones and never have to do it again. As to cost effective, what is my time worth trying to find antique parts in junkyards, or driving to wherever there might be some mopars in a junkyard, or cleaning and repairing the old parts that, after all, were in the junkyard for a reason? I know some folks find joy in the hunt, but I keep thinking of the cartoon of the two buzzards sitting on a limb and one says "Patience my azz, I'm gonna go kill something"
Of course opinions differ, and I thank God for that. Wouldn't it be boring if everybody had the same opinions?
ATB
BC
PostPosted: Wed Nov 14, 2012 4:17 am
A Ford is a Dodge.
Frikken
Old
Rebuilt
Dodge
I am a hot rodder. I don't care what brand parts I use, as long as the beating heart is Mopar. 8)
PostPosted: Wed Nov 14, 2012 1:47 pm
The poly bushings on Ryan's Duster squeak setting still!! Don't think I would go that route if I planned to drive it a lot.
Also, I don't remember what car you have, But you can do the F body spindles and control arms a lot cheaper than even the 73-76 A body stuff. I bought the complete front set up on Ryans Dart for $50. I cleaned, painted, and installed new bushings, and it was ready to go. This set up is debated too, but it works fine and has been on my sons car for several years.
Rick
Whoops!! re-read the thread! You don't like junk yard runs. Scratch the above that I wrote. All new stuff will set you back a bit. :lol:
PostPosted: Wed Nov 14, 2012 1:54 pm
Ask extra questions when you're shopping around, then; take care you don't get a Canadian axle. That'll be difficult, because starting in 1967 Canadian and US autos and parts flowed freely across the border in both directions and a lot of cars sold new in the States were made in Canada. But it'll be worth the effort so you don't wind up with a foreign axle in your car.
Because we don't live in a yes/no, either/or, black/white kind of world, that's why.
Look, nobody's going to force you to give up your preferences and opinions and priorities—nobody can. But you are building a car nearly half a century old (and statistically doesn't exist), the newest cars that could provide a direct rear axle swap are 37 years old (and mostly no longer exist), the newest Mopars that could provide a rear axle swap with some reworking and alteration are 24 years old (and few and far between). That means your "cost effective/logical" and "100% Mopar" goals are in direct conflict. You will either have to bide your time and wait until you stumble upon the axle you want, or choose which is the higher priority.
PostPosted: Wed Nov 14, 2012 6:08 pm
Yes, they have! Should arrive about the middle of next week. I'm also paying someone to do the install. I don't have the tools, experience, or safe work place. Thanks for all the comments, folks. Progress report will follow.
ATB
BC
PostPosted: Fri Nov 23, 2012 3:15 pm
If you're going down mountain roads, bigger brakes are better because it's harder to overheat them (this is where you won't be able to lock up the 9" brakes)
While I respect emsvitil's opinion, I gotta agree with Dan when it comes to brakes. I've had a variety of A-bodies over the years as daily drivers. 13", 14", 15" tires, (bias & radial); 9" & 10" drums; manual & power disc .
You CAN live with drum brakes, but you have to drive very conservatively- but all it took was one emergency stop from highway speeds to convince me that drums are NOT adequate for modern traffic patterns (ie, longer stopping distances than other cars, wander & pull, etc). Forget mountains, a minor hill descent will overheat 9" drums with 14" radials. Don't overlook how poorly drums function if you get them wet at all (ie, drive thru a puddle).
63 Valiant Wagon
225 - 4 bbl
PostPosted: Fri Nov 23, 2012 3:37 pm
What's foreign? As Dan stated stuff went back & forth- three of my Darts were Canadian made. Of course definitions shift if you're north of the border to begin with.
Those great Nipondenso starters were designed in Japan & built all over the globe. Lots of "imports" are built/assembled in US plants.
Of all the criteria to use for a parts upgrade choice, the original car brand (Mopar-GM-Ford etc) is pretty far down on my list.
63 Valiant Wagon
225 - 4 bbl
PostPosted: Sat Nov 24, 2012 12:06 am
Well. y'all may be surprised at this, then! I've found a really nice set of front seats out of (brace yourselves) a '97 Mercedes E320! :shock:
And the star is going on the dashboard! 8)
So. how's that for living in a black and white world, folks?:D :D
ATB
BC
