It is currently Mon May 11, 2026 4:08 pm
PostPosted: Fri Nov 30, 2012 9:28 am
Car Model: 1964 Valiant V200
I got one of the Offenhauser intakes, and I assumed (wrongly) that I could use my stock air cleaners on it. They are about 11.5" diameter and the carbs are 10 inches on center. Short of cutting and welding I'm wondering if there are any nice-looking (i.e. stock looking) alternatives?
PostPosted: Fri Nov 30, 2012 9:52 am
Use 2 of the 62-65 factory 1bbl air cleaner assemblies.
PostPosted: Fri Nov 30, 2012 11:06 am
Weird, I must have the wrong air cleaner because mine is bigger than those. It's 11 inches in diameter. And my car is a 64 Valiant that has been in the family since new. Someone must have swapped it???
PostPosted: Fri Nov 30, 2012 12:27 pm
Yes, It sounds like you have the later unit.
The thing to watch-out for is the top "bail" that mounts to the carb & holds the screw stud for the air cleaner assembly. The "small & tall" air cleaner uses a taller "bail" to hold it to the carb.
PostPosted: Fri Nov 30, 2012 1:45 pm
Thanks. More parts to add to my shopping list.
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Bing [Bot] and 7 guests
