It is currently Tue May 12, 2026 4:51 pm
 Post subject: Smashed electrod
PostPosted: Thu Nov 29, 2012 7:20 am
After making a 60 mile trip my 77 Aspen started running rough coming down Main Street. When I got home I pulled the plugs and found the electrode on the #2 plug bent over to the side and 1/4 of the insulator missing. So what happened?????? Both bolts on choke plate are still there.
A quick comp check showed 85 PSI compared to 105 on #3
If I have time I'm going to pull the valve cover off when I get home tonight.
Thanks In advance Mike[/img]
Thanks Mike
PostPosted: Thu Nov 29, 2012 10:14 am
Well, we know that your plug to piston clearance didn't suddenly change, so perhaps the insulator cracked, fell down into the cylinder and got mashed into the electrode.
I think I would install another plug, crank the engine over with the coil disconnected, and then remove the plug to see if it is undamaged.
- Mac
PostPosted: Fri Nov 30, 2012 2:22 pm
I cranked it over with out plug before I stuck my compression gauge in it. I put a new plug in it and cranked it over, then started it and ran it a couple minutes. The gap was the same as when installed.
I guess I will pull the head come spring and look at everything just for piece of mind. I would do it now but I'm headed back to work for 28 days.
Thanks Mike
Thanks Mike
PostPosted: Fri Nov 30, 2012 10:00 pm
Autolite? Champion? What brand?
PostPosted: Sat Dec 01, 2012 7:46 am
NGK's that have been in car for 10,000 miles at least.
Thanks Mike
PostPosted: Sat Dec 01, 2012 4:11 pm
Some detonation/pinging may have cracked the porcelain.
Then it broke off, bounced around and bent the electrode.
PostPosted: Sat Dec 01, 2012 4:18 pm
More than likely the detonation took the top of the piston land off
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 15 guests
