It is currently Sat Nov 28, 2026 2:05 am
Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2
PostPosted: Sun Dec 02, 2012 3:51 pm
Thankyou guys...I'm soaking all this info in. Much appreciated!
PostPosted: Sun Dec 02, 2012 5:03 pm
and a M1 is just aluminum version of the export 2v that the Direct Connection folks marked up in price.
Say what????? Export 2V? I have the M-1 on the Duster. I got it cheap years ago.
PostPosted: Mon Dec 03, 2012 9:30 pm
Cheap is relative, when the M1 was new, it cost more then a new Offy 4v manifold and Dan can explain the "export 2v" manifold thing.
PostPosted: Mon Dec 03, 2012 9:51 pm
Cheap as in never used, with Holley 318 model 2bbl.
PostPosted: Tue Dec 04, 2012 1:11 pm
Rug,
Are you happy with it?
Warm up quick?
I have been trying to find one for years......seen two for sale and lost out on both of them.
Others I have seen where on drag cars and performed well!
I love the two aluminum one barrel manifolds that have....they run very well.
PostPosted: Tue Dec 04, 2012 7:34 pm
Rug,
Warm up quick?
I have the Hookers with the heat riser pipe plate. Nice piece!
PostPosted: Sat Dec 08, 2012 5:40 pm
The Clifford I just got has bosses on the tops of the runners. Are they big enough to drill for injectors?
PostPosted: Sat Dec 08, 2012 6:12 pm
I believe so. I have seen pictures of a clifford intake with bosses drilled for fuel injectors. you need either a 17/32 or a 13.5mm SMOOTH hole for standard fuel injectors. I drilled and welded my offy intake for the injector bungs since i couldn't justify the cost of a clifford since I already had this one.
Users browsing this forum: DuckDuckGo [Bot] and 3 guests
