It is currently Sat Nov 21, 2026 10:16 am
PostPosted: Wed Nov 14, 2012 3:19 pm
I didn't have a thread of my own regarding the kickdown for my Holley 390+Offy setup, so I'll just add my 2c with the Bouchillon kit right here. Like has already been mentioned, it's neat, simple, pretty, goes in in 45 min (my header added about 15min haha), and quite expensive compared to any of the homebrew options. It was a great choice for me because I'd rather spend my limited time messing with the carb tuning right now than preventing my 904 from burning up.
PostPosted: Mon Dec 03, 2012 10:51 pm
So I went ahead with the Bouchillon kickdown for my Holley 2280, because I've got money to burn. :roll: I read the instructions carefully (messy and confusing though they may be), went to mount it up the other day and quickly ran in to a problem. The Bouchillon bracket won't sit cleanly on the OE accelerator cable mounting bracket (see here and here). But even if it did, where would I then be mounting the accelerator cable???
wjajr, it says that part is designed for 4 bbl setups.
J.R.
Tucson, AZ
'68 Dart 270 with a '76-'80 engine
PostPosted: Tue Dec 04, 2012 4:45 am
You may need one of these Accelerator Mounting Brackets to complete conversion. Also one of the studs holding carburetor may have to be longer to receive the bracket and have enough thread to run a nut onto it.
SSDan said the kit is mostly factory parts, and it is.
I said:
Bouchillon universal accelerator cable mounting bracket can be used with the junk yard parts. Also if you can find a bracket off of a cable operated automatic transmission Chrysler built car or truck with carburetor that has cable ends orientated correctly it may be made to work.
Bouchilon said; for 4 barrel carbs.
You could change the direction of the bolt holding kick-down cable so it can slide into its hole, and mount accelerator cable on opposite side of that bracket piggy backed just like the 4 barrel adaptor bracket holds both cables.
Sorry to have miss lead you, in the two barrel case some cobbling up looks to be needed.
I'm sure others here have used this cable on the same carb you are attempting to adapt to, perhaps they can post a photo of their set-up.
PostPosted: Sun Dec 09, 2012 10:02 pm
All I did was take a few simple measurements from the wrecking yard cadaver. Length from the adjustible cable housing mounting bracket to the cable end atached to the throttle body, 4 inches. Length from the throttle shaft to the cable end, 1 inch. Or the large hole on the bottom of a holley 600 double pumper. I welded up a bracket for the throttle cable and tv cable using the wrecking yard parts and bolted it to the carb. The best adjustment I found was to pull all the slack out of the cable with the adjuster, then open the throttle wide open allowing the cable to pull the adjuster till it stops. you may have to flirt with it, in and out to get the shift points where you want them but it was spot on for me. Shifts at 5600 at wot. All of the parts were taken from the same 95 dodge dakota.
PostPosted: Thu Aug 21, 2014 5:30 pm
Hey all, I think the link to the Bouchillon kit for the kick down is dead (reason:time, I guess). Is it this part?
http://bouchillonperformance.com/inc/sdetail/586/589
Thanks in advance.
Greg loves his daily driver.
1973 Swinger 225 /6 Seats 6
PostPosted: Fri Aug 22, 2014 6:16 am
Mancini Racing has same setup now for sale.
[url=urlhttp://chucker54.stores.yahoo.net/retobotokica.html]Cable[/url], and univercile bracket.
Other stuff Mancini has for kick down or throttle pressure cables of a more generic nature here.
 Post subject: Re: Kickdown or Lokar?
PostPosted: Mon Oct 15, 2018 8:13 pm
So I have a Super Six setup with a Carter BBD from a 77 Volare. Kickdown linkages are seemingly increasingly hard to find so I was wondering your guys opinion on this. Would it be better to get the stock super six kickdown or a Lokar cable? I have a 904 Trans if it matters. Oh, and what part numbers would I need for the cable and other brackets I would need? This is all on a 72 Dart Swinger. Thanks!!
IMO, Cable is the only way to go - and lokar makes the best. Smooth operation. No routing problems that linkage can cause, especially if you are running headers or other no-factory stuff. Infinitely adjustable. Here is the Lokar set up on my street rod ( 727). Steel jacketed cable in the pic attaches to the trans throttle lever. Only thing you have to duplicate from the linkage set up is the distance from the carb throttle shaft to the cable attachment point.
