It is currently Wed Jul 15, 2026 8:27 pm
 Post subject: Drag Radial storage?
PostPosted: Tue Dec 04, 2012 4:17 pm
I know folks try and take their slicks and store them in "warmer" temps over the winter. Is there any reason to do the same with Drag radials? I have another set of wheels I can swap onto my car for the winter, but didn't know if it mattered?
Thanks,
Rick
PostPosted: Tue Dec 04, 2012 6:28 pm
If nothing else, I would jack the car up and put stands under the frame so the weight is off the springs and tires. Then at least they won't flat spot.
PostPosted: Tue Dec 04, 2012 7:06 pm
No Reason no not heed these suggestions if your car is just sitting.. I Remove the Racing Tires - air them down to 5 PSI and Stack them in a corner of the basement (which is Heated) I dotn cover them 'cause My basement is dark unless I am working in there.. and I try to keep them away from electric Motors.
More Infos Below..
http://www.hoosiertire.com/safetywarning/index.htm
http://www.mickeythompsontires.com/tech.php?bulletin=s5
PostPosted: Wed Dec 05, 2012 3:18 am
Thanks! I'll swap them off and store them in my basement.
Thanks, Rick
