It is currently Sat Nov 28, 2026 10:30 am
PostPosted: Wed Dec 05, 2012 7:17 am
Three on the Tree
hi Bear R.- here and wondering if i go w/the new torque specs of 5-7 lbs .(back of package).or do i stick w/10lbs.?thanks and God Bless Bear R.-
1967 Dodge Coronet 440. 225cid. 3 speed column shift.radio delete
 Post subject: RemFlex
PostPosted: Wed Dec 05, 2012 12:39 pm
I have found going lighter is better than heavier on torque. If you crush the gasket the movement of the manifolds will be reduced. That is a bad. You don't want them so tight that they will crack from multiple heat cycles and from being too tight. I made the mistake of over tightening my first gasket which was entirely unnecessary...It will seal well with lighter torque when compared to a Felpro.
I use a inch pound torque wrench an make several light passes to gradually snug up the manifolds. This way they can move around during the heat cycles and not crack the exhaust manifold and still seal very well. Much, much better sealing compared to the the stock steel gasket which always seemed to leak somewhere.
 Post subject: Yep...
PostPosted: Wed Dec 05, 2012 6:04 pm
That would be a good start, I've gone 10-15 if using a 'conglomeration' of parts (i.e Clifford Hyperpak, Dutra Front Manifold, Stock Modified rear manifols)...where you have 3 parts sliding at different rates...I've gone as far as 20 lbs as a 'final' torque for them, but as stated, that's a one shot deal...no more torquing and not reuseable even if you 'PAM' the gaskets.
PostPosted: Wed Dec 05, 2012 9:43 pm
Just thinking...........
Since ideally the manifold expands out from the center; would variable torque settings be good.
Have the middle bolts tighter to keep the manifold aligned and in place, then have the outer bolts looser so the manifold can move.....
PostPosted: Thu Dec 06, 2012 5:32 am
Three on the Tree
Thanks guys.remflex is the only way ill go .i dont know much about slant sixes.but i do love'em.and getting to know them.one thing i dont like is somone put a comp cam in it when he rebuilt it.i hear bad things w/oil pumps w/those cams.well take care and God Bless.Barry
PostPosted: Fri Dec 07, 2012 5:13 am
Three on the Tree
HI JUST GOT A CALL BACK FROM REMFLEX.5-7 LBS IS CORRECT!!!!!...THANKS AND God Bless..Bear R.-
 Post subject: Remflex gaskets
PostPosted: Fri Dec 07, 2012 7:28 am
I worked with (Remflex) early on finding the best torque specs and spraying the gaskets with PAM or Teflon. I tore up a few of the first sets of gaskets from over torquing and they were gracious enough to send replacements. It is a different learning curve working with this type of gasket material and since they are so thick. The temptation is to over torque and crush them. To avoid this I use brass nuts and a small inch pound style torque wrench. It is important to let the manifolds move around as they expand and contract during the heat cycles so they do not crack yet make a good seal.
PostPosted: Fri Dec 07, 2012 9:10 am
After 2500mi I have yet come to any problem with 10ftlbs on the remflex
