It is currently Sat Jun 13, 2026 8:24 am
 Post subject: I'm an idiot, I think
PostPosted: Mon Nov 17, 2003 9:51 pm
regarding my carb leak, which way is the rubber tip of the inlet needle suppose to point, towards the fuel line or towards the float?
PostPosted: Mon Nov 17, 2003 10:05 pm
Toward the fuel line.... Ya idiot.:mrgreen: :mrgreen: :mrgreen:
PostPosted: Mon Nov 17, 2003 10:08 pm
shazaam!!!!!!
(think that might be my problem?)
PostPosted: Mon Nov 17, 2003 10:20 pm
Sorry, couldn't help myself! Plus, I like Mr. Green...:mrgreen:
PostPosted: Mon Nov 17, 2003 10:37 pm
live and learn, right?
I'll say one thing, though. I've learned all kinds of stuff from this frustrating, yet worthwhile experience. I bet I could take apart and reassemble my carburetor with my eyes shut now. Well, except for the inlet needle. I'd have to peek on that.
 Post subject: ...an idiot...
PostPosted: Mon Nov 17, 2003 10:52 pm
:P :P
We all knew you'd find your problem if you did not despair. You see, it's the little things like that what make this hobby interesting and enjoyable.
:P :P
Andele, ándele...arriba, arriba!!!!
(Speedy Gonzalez)
Rafa
Hecho en México
PostPosted: Mon Nov 17, 2003 11:44 pm
Look inside where the "rubber tip" fits (fuel line side) and you'll see how it acts as a seal. Based upon how much fuel is in the bowl, the float rises and falls. Mock fit everything together and work the bowl up and down with your fingers and you can see how the little tab will press against the needle valve and press it into the tapered hole, effectively sealing off the fuel from entering and over-filling the bowl.
Jerry
PostPosted: Tue Nov 18, 2003 4:42 am
If the needle was installed backwards, you may want to replace it. The tip of the needle is easily damaged. You can buy just a needle/seat (brass fitting that screws into the carb bowl) seperatly.
Users browsing this forum: Ahrefs [Bot], Rick Covalt and 3 guests
