It is currently Wed Jun 17, 2026 2:24 am
 Post subject: It's alive!!
PostPosted: Mon Nov 17, 2003 8:47 pm
The new 225 is in and running great. Well almost...I'm having some timing and idle issues. If I set the timing at TDC (per the book), I have to set the idle screw pretty much all the way in to keep it from stalling, especially when I put it in gear. The carb is the original stock Holley 1920 and the dist. is original stock (points) as well. I have no idea if anything has been done to either of them in the past. What should I check or do to get the timing and idle right? Thanks in advance! :D
Future replica police unit: 1968 Plymouth Belvedere 4-Door (aka "Christine," according to my wife).
PostPosted: Mon Nov 17, 2003 10:29 pm
I would put more initial timing / advance into it.
Most Slants like 8-10 degrees BTDC.
Test drive and retard the timing if you hear it ping.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 1 guest
